Post by mobiltec on Aug 3, 2021 8:41:20 GMT -8
I always start making a punch list when I get past the metal. And that punch list seems to grow as fast as I mark stuff off. I am down to the final punch list on the Mainline now and I've still added a few things. Deadlines do not bring anything to the table but stress and dissapointment. This is a hobby and it's supposed to be fun. If it was a job and you made your living from it then it would be different. But I've done that too and it never works out.
PT
Post by PT on Aug 4, 2021 17:02:07 GMT -8
PT
Post by PT on Aug 7, 2021 18:22:34 GMT -8
Post by vikx on Aug 7, 2021 19:27:41 GMT -8
Vent Fan looks great! Be sure to check every year to touch it up if need be.
PT
Post by PT on Aug 12, 2021 8:18:44 GMT -8
Yay! Front trim is in on both sides I would have loved to reuse the originals but rebuilding the front end changed the profile too much to make them useable. HH originally did these as one continuous crazy bendy piece but I broke them up into two. Between cutting, annealing, cussing, bending, tapping, masking, sealing, pre-drilling, screwing, cleaning and more cussing these two pieces took close to 8 hours to get done. I have no idea how it could take that long but it did. Not perfect but not bad...
Post by mobiltec on Aug 12, 2021 10:06:50 GMT -8
I see that you have buckling in your radius. I made a 3/4 inch thick plywood jig to preform my corner cap rail in and it worked great with no buckling. Bet you did yours by hand. I have a video that shows me doing it for the wheel well but I also did it on the sharpest radius on the back of the trailer as well. On that one it began to buckle a little bit in the jig and once I had it completely closed I just beat on it with the mallet and it flattened right out. Then I installed it with no problems. If you want to look here is the video. Video Link: youtu.be/v476CBqvPUQ
Post by Teachndad on Aug 14, 2021 5:13:08 GMT -8
Yay! Front trim is in on both sides Between cutting, annealing, cussing, bending, tapping, masking, sealing, pre-drilling, screwing, cleaning and more cussing these two pieces took close to 8 hours to get done. I have no idea how it could take that long but it did. Not perfect but not bad... Are we having fun yet? 8 hours for two pieces. That IS determination. I always wanted a HH before reading about your restoration. But, now.... Big ATTABOY!! to you, PT. Rod
PT
Post by PT on Aug 16, 2021 19:13:13 GMT -8
Welcome to the Holiday House - or at least the part with the front door finally installed. Needs to be fiddled with but does what it's supposed to. Being a suicide door I think it will have a bungee chord forever strapped to it while we're in motion.
Post by mobiltec on Aug 17, 2021 9:38:22 GMT -8
If the door is hung properly there should be no reason to be worried about the door coming open during travel. And a nice little trick that a lot of companies like Westerner did with their suicide doors was to put a piece of J Rail along the forward side of the door. That caught not only the wind, but also rain when traveling so it helped keep the air and water from getting under the flange of the door.
PT
Post by PT on Aug 17, 2021 19:41:53 GMT -8
The main concern will be my never ending capacity to be an occasional idiot.
I will be busy and see something shiny while I'm "closing" the door in a year or two - lose my concentration and drive off with it not completely latched and..... I added the latch plate that provides another 1/8 inch of grab so that helps but I will use a bungee to make it idiot proof-ish :-) too!
PT
Post by PT on Sept 20, 2021 9:29:37 GMT -8
Post by mobiltec on Sept 20, 2021 16:14:54 GMT -8
Well I only beat ya by a couple of weeks but she's sure lookin good my friend.
aslmx
Post by aslmx on Sept 21, 2021 18:04:10 GMT -8
Work of art. Nice job.
PT
Post by PT on Sept 29, 2021 12:17:44 GMT -8
Here's a walkaround/through with me babbling about the HH :-)
oldman
Post by oldman on Sept 29, 2021 14:49:35 GMT -8
Nice work man, looks great!
