back2denali
1969 Shasta Compact
Post by back2denali on Oct 9, 2018 13:52:53 GMT -8
Are these the correct lights for a 1969 Shasta Compact? You can see from the left side pic that not all of the screw holes are being used; the right side lens is broken and looks like water got behind it so I am going to replace and seal these. The lights are embossed with "Auto Lamp 576 Chicago" on the left and "Auto Lamp 575 Chicago" on the right. I like the idea putting the old car-style lights instead but might just go with cheaper (and easier) vintage Shasta-style. I know they are readily available.
datac
1957 Cardinal
Post by datac on Oct 10, 2018 8:07:37 GMT -8
Yep, those are likely original to your trailer. The same lights were also sold as Reflect-O-Lite 110s. They're bigger and deeper than the Bargman 98/99s that are available in reproduction. I have a set a PO put on my trailer back in the '60s- I'll likely be selling them, good lenses with rusty-ish backplates.
Post by vikx on Oct 10, 2018 19:37:37 GMT -8
Note: Pathfinder 575/6 do not match Reflecto 110s... be careful buying online.
back2denali
1969 Shasta Compact
Post by back2denali on Oct 11, 2018 4:29:43 GMT -8
Didn't know they were called Pathfinders. That's what I'll look for.
Post by Ten on Oct 11, 2018 16:38:25 GMT -8
On my 1970 16SC, presumably original to the trailer.
57 Trotwood
Post by 57 Trotwood on Oct 12, 2018 7:42:34 GMT -8
I am kicking around an idea, I bought 57 Mercury car tail lights at a swap meet and I may put them on my 57 Trotwood. I will even hook up a wire for the reverse lights to go on. The trailer now has damaged old lights so I think it will be cool.
back2denali
1969 Shasta Compact
Post by back2denali on Nov 1, 2018 9:08:23 GMT -8
On my 1970 16SC, presumably original to the trailer. So these are Reflectolite 110's? on your Shasta Compact? Would you mind measuring the diameter of the mounting plate? I have to replace the entire light assembly because of corrosion and poor sealing. The new ones need to cover the holes drilled for the original lights.
