kaffi311
1963 Shasta 16 SC
Post by kaffi311 on Sept 10, 2018 17:10:00 GMT -8
So I am cleaning up my front Hehr window- 4 panels- 2 outer ones are solid glass, 2 inner ones are louvered. I have a few questions: 1) What is this part? It is only on the one side of one of the solid glass pane panels. I am confused ! IMG_4468 by kathy, on Flickr IMG_4467 by kathy, on Flickr IMG_4469 by kathy, on Flickr 2) . In the corners of the window frame (many places) there is this silver hardened sealant- it looks original, but I don't know. Is it perhaps JB Weld? I have removed most as it was coming off in most places- but want to know what to redo it with IMG_4472 by kathy, on Flickr IMG_4465 by kathy, on Flickr IMG_4470 by kathy, on Flickr Thanks all ! Last window- Whoo Hooooo!!
Post by turbodaddy on Sept 10, 2018 17:55:01 GMT -8
I'm just guessing, but I think the "part" is a spring to absorb the sliding action when closing the solid glass panels. The goopy stuff does look like JB Weld, possibly a misguided attempt at sealing a leak which most likely originated somewhere else?
Post by vikx on Sept 10, 2018 19:34:48 GMT -8
Gutter seal will replace that goop. Be sure it's dry and use another dab if need be.
kaffi311
1963 Shasta 16 SC
Post by kaffi311 on Sept 10, 2018 20:40:14 GMT -8
I'm just guessing, but I think the "part" is a spring to absorb the sliding action when closing the solid glass panels. Thanks for the response- however the solid panels don't slide- they are stationary. Perplexing me !
tehachapibob
69 Shasta Stratoflyte
Post by tehachapibob on Sept 11, 2018 11:05:10 GMT -8
tehachapibob
Post by tehachapibob on Sept 11, 2018 11:13:30 GMT -8
That's not JB weld but Alumiweld. If properly done pretty much fuses the two parts together. Search on Web to see how it's done.
kaffi311
1963 Shasta 16 SC
Post by kaffi311 on Sept 11, 2018 12:33:42 GMT -8
That's not JB weld but Alumiweld. If properly done pretty much fuses the two parts together. Search on Web to see how it's done. Will do- thanks! So..no one knows what that part is? I cant figure it out ! THanks
