tehachapibob
69 Shasta Stratoflyte
Post by tehachapibob on Jul 21, 2018 8:49:57 GMT -8
Does anyone know what I can use to bond a silicon seal to aluminum? Weather stripping glue does stick at all. The window seal I have is too loose to hold itself in.
Post by vikx on Jul 22, 2018 20:17:41 GMT -8
Your seal may be the wrong shape or size. On my 57 Shasta, the seal goes on the metal, then the screws tighten the seal up against the glass. There are many screws, about 2" apart. As the screws tighten, the seal is squeezed
Please give us a little more info. Which type of window? Or is it the Shasta dinette windows?
tehachapibob
Post by tehachapibob on Jul 24, 2018 18:45:20 GMT -8
These seals are on a 51 Spartan Spartanette. The rear window seal sits in a channel for the window but not held in tight, I wanted to glue them in but needed to know what would work.
