Post by photopoetess on Jun 29, 2018 21:58:10 GMT -8
Newbie here. Hello! Lots of great info here.
My boyfriend has a 1968 Aristocrat Lo Liner trailer that he takes great pride in and loves. From what I understand, it is rare due to the fact that it has a bathroom, shower and a top side fridge. It seems to be in great shape and is fully operational. We have had many wonderful memories in it.
I have recently accidentally broken a few of the jalousie window panes/slats and am eager to replace them. After reading several threads here, this is what I have gathered: Remove the screen and take one of the good panes to a local reputable glass shop, tell them what I am using it for and order replacements and an extra for any future mishaps. I should request tempered glass and that all four sides be ground. This sounds good to me and I'm all for it, but my boyfriend states that the glass will not be the same color or quality as the originals. Will the replacement glass be sufficient and undetectable of differences from the originals? Would I be better off trying to find original 1968 glass panes, and if so, where might I do that? I found some on ebay and the measurements are close, but not exactly the same.
1962 Forester- 1959 Shasta
Post by nccamper on Jun 30, 2018 4:13:06 GMT -8
Welcome!
I replaced some glass on a 63 Shasta. A glass shop will take one look at the old (broken) glass and know whether they can match it. I had a hard time finding a place like that here so I ordered these from Home Depot:
They were a little thick for my windows so I bought several panes from a member who salvages old part for vintage campers. Here is his email: trailertrasher1@gmail.com
Post by photopoetess on Jun 30, 2018 8:10:48 GMT -8
Thank you very much nccamper! I appreciate you taking the time to respond. Happy camping.
aslmx
Post by aslmx on Jun 30, 2018 18:23:01 GMT -8
My Hehr windows had 3/16” glass originally but the glass shop didn’t have it. All they had was 1/4” and it worked fine. I wouldn’t use tempered but by law, I was told, if it is on a trailer it has to be tempered. I told them it was for an old shed which is basically what it is if I don’t get out there and finish it.
Post by vikx on Jun 30, 2018 20:34:45 GMT -8
Asimx is correct. Don't get tempered glass. It's the worst. 3/16 x 4 is what most of mine have been. The adjustments occur with the thickness of the glass pads.
Post by mel on Jul 1, 2018 3:39:50 GMT -8
I had ace hardware cut me a few. They seemed to have the correct size thickness
chriss
Post by chriss on Jul 1, 2018 8:06:05 GMT -8
As far as quality goes, I don't see how modern glass is inferior to the vintage stuff. There are different grades of glass, usually having to do with waviness and bubbles, but it's pretty rare in modern glass. Yes, the new glass will stand out against the old because it doesn't have the water deposits, scratches, and slightly sand blasted look of the older glass. You can't hide this. What you want, as mentioned, is untempered 3/16 x 4" × whatever length. You want the ground edges. I think it's called a pencil grind and it comes in a clear or frosted. Just match your originals. I had to replace 2 and the glass shop wanted $35 for both. If I could afford, I would replace all 14.
Post by photopoetess on Jul 1, 2018 13:01:19 GMT -8
Hi Guys! Thank you aslmx, vlkx, mel and chris for responding. I really appreciate it.
Post by vikx on Jul 1, 2018 19:43:29 GMT -8
chriss, try a local small glass shop. Mine are around 5 bucks or less each.
oakback
Post by oakback on Jul 3, 2018 11:13:02 GMT -8
Why is tempered bad? Easy to accidentally shatter with exposed edges like that?
Post by vikx on Jul 3, 2018 18:45:45 GMT -8
If it breaks tempered does shatter, EVERYWHERE.... To me, it isn't as strong as the regular panes.
ruderunner
Post by ruderunner on Jul 4, 2018 2:05:57 GMT -8
Yes it scatters, but it ends up in fairly dull edged chunks rather than sharp edged shards.
Tempered is a pain to clean up but you won't bleed when you find a piece you missed.
Post by vikx on Jul 4, 2018 20:33:10 GMT -8
I like a little blood... proves I did the work. LOL
