kaffi311
1963 Shasta 16 SC
Post by kaffi311 on Jun 9, 2018 13:49:10 GMT -8
I am installing my toilet. It already has a rubber gasket on the bottom- but I was going to use a wax ring. Do I use both- or just one? And which one? Thanks Kathy IMG_3451 by kathy, on Flickr
Post by vikx on Jun 9, 2018 20:59:08 GMT -8
Are you using an RV flange? If so, just the rubber gasket. Most RVs don't use wax because of the heat inside when in storage.
Post by Ten on Jun 10, 2018 5:36:56 GMT -8
If that is the original rubber ring, you may want to replace it. The dryrot just like any other rubber product. It probably would never give you a problem, but if replacement is easily possible, why run that risk?
You don't need a wax seal, the rubber seats against the floor flange. They are built so that the outlet inserts into the flange.
kaffi311
1963 Shasta 16 SC
Post by kaffi311 on Jun 10, 2018 17:46:12 GMT -8
Are you using an RV flange? If so, just the rubber gasket. Most RVs don't use wax because of the heat inside when in storage. Yup- using the flange that was there originally- as it is metal and will not come off. Thank goodness it is in good shape. THanks !
kaffi311
1963 Shasta 16 SC
Post by kaffi311 on Jun 10, 2018 17:46:38 GMT -8
I did buy a new one- thought that was a good idea! Thanks ! K
