Poquito
Post by Poquito on May 28, 2018 9:14:04 GMT -8
I'm replacing my tires before my first big road trip from FL to NC to see my mountain girl daughter this summer. I know I want a radial tire but would like to see if there are any particular brands that folks like for their camper tires. I want to stay around the $200 range for both tires - no need for wheels. FYI- my trailer weight is under 2k. I'm sticking with my wheels if it'll save me money for now. If it is a brand that my local trailer shop or Discount Tire can order, I'll have them put them on for me.
Any suggestions? Thanks, Poquito
chriss
Post by chriss on May 28, 2018 14:06:28 GMT -8
I got mine through etrailer. 5.30x12 radials with an E load range. My local stores only had them in bias ply with a max C load range. You didn't mention your size, but they have a huge selection. Mine are Kendas.
Post by Ten on May 28, 2018 17:30:26 GMT -8
You should get lots of different opinions regarding tire brands, there are plenty to choose from. Here's mine...
I put Maxxis M8008's on my 16SC. They are 8-ply radials shipped to my door, bought off of a supplier on eBay.
I would only be guessing at the size, mine are 15", but here's an example:
Post by mel on May 29, 2018 3:50:46 GMT -8
Ten what kind/size did you put on your Airflyte?
Poquito
Post by Poquito on Jun 9, 2018 3:13:19 GMT -8
Since I couldn't find trailer 15's the same size as the ones that are on there, (they are not trailer tires and don't appear to be the right weight rating) I found 13's that match the size. 205 15's were going to be too big and potentially damage the wheel well if the camper hit a pot hole. I couldn't find 14's that were the right size either so the 13" matched and hopefully will go on without too many band-aids. From eTrailer.com I bought Westlake ST175/80R13 - Radial tire has 6-ply rating and 1,360-lb max load at 50 psi. Nitrogen fill maintains tire pressure. 1-Year No Excuses Guarantee on tire. 2 years complimentary roadside assistance included. Flat tire service available 24/7 anywhere in the United States, Canada, or Puerto Rico. Steel inserts in lug nut wells help to keep wheel securely in place... I chose the Jaguar aluminum wheel with split-spoke design. Couldn't help it- a bit of hot-rod still in my blood. www.etrailer.com/Tires_and_Wheels/Westlake/LHAXSJ101G.htmlPoquito
