CorvettCrzy
'58 Corvette, '64 Franklin
Post by CorvettCrzy on May 7, 2018 15:35:53 GMT -8
I know I have posted this picture before but it wasn't until yesterday that I took a closer look at it that I realized there appears to be a part missing for the center burner. Does anyone know what it is and what it might be called? Where would I find such an item? An RV store? DSCN0757 by Corvett crzy, on Flickr Thanks for any help.
shastatom
Shasta 54,57 1500 58 Airflyte
Post by shastatom on May 7, 2018 18:10:18 GMT -8
CorvettCrzy
Post by CorvettCrzy on May 7, 2018 18:54:11 GMT -8
I felt that the bracket had been bent see first picture, so I straightened it a bit and it closed the gap. My husband thinks all it is missing is the piece with the very small pin sized hole in it, but I'm not sure how it would hook up to the "nipple" on the end. Second pic. Missing part? by Corvett crzy, on Flickr 2018-05-07_10-51-32 by Corvett crzy, on Flickr Stove assy by Corvett crzy, on Flickr It would be very helpful if someone knew what that was called.
CorvettCrzy
Post by CorvettCrzy on May 7, 2018 18:56:09 GMT -8
Thanks so much for the website shastatom I will email them and see if they know anything about RV stoves!
msgoehring
1957 Westerner Deluxe
Post by msgoehring on May 8, 2018 3:33:07 GMT -8
It doesn't look like you are missing anything going by what my stove looked like when I took it apart. Have you taken either of the other two apart to see if they look like that one? The only difference between the burners will be that the middle one has the extension pipeline so it can stretch out where it needs to go. I'll see if any of my pictures show my burners apart and upload them if so if it will help you out.. also, that store place doesn't do rv stoves, only apartment size and bigger that were used in homes. I tried to get help from them before. EDIT: my pictures won't help because my stove is so much older than yours and set up a bit different, sorry o
