charliemyers
Post by charliemyers on Apr 7, 2018 4:33:00 GMT -8
lol....I’m certainly not the one to ask because I pull my Compact with a Silverado 3500HD.
Post by turbodaddy on Apr 7, 2018 18:56:01 GMT -8
If you're only moving the camper around once in a while, a smaller truck will be fine. If you want to actually travel cross country without worries, mountains or not...go for the 6500 lb plus tow rating, transmission cooler, V8 engine, brake controller, 4WD, all the bells and whistles. You will not regret it when things get troublesome.
speak
1959 Shasta Airflyte
Post by speak on Apr 9, 2018 16:38:52 GMT -8
Thanks turbodaddy. I'll probably go more with the larger truck w/tow package etc. as suggested. Looking at some cross country with the 59 when we are finished. Also, Still moving kids in and out of apartments etc. It will prove it's weight in gold for that reason alone.
strange1
1965 Shasta Airflyte
Post by strange1 on Apr 10, 2018 13:33:54 GMT -8
I'm headed out in 2 weeks. I'm towing my '65 Airflyte with our Chevy Colorado. I'm sure others will chime in before then...but this will be our maiden voyage and I'll be happy to report how it goes. Here's looking to the weekend of April 20th. What year is your Colorado? Please do report back after and have a wonderful time on your maiden voyage in that pretty camper. My Colorado is the old style...not the newer bigger trucks. 2010... it has the 3.5L 5-cylinder motor in it and has been a very good truck. I'm considering a full size truck but have got this for now. I'll let you know how it goes.
speak
Post by speak on Apr 10, 2018 16:57:22 GMT -8
What year is your Colorado? Please do report back after and have a wonderful time on your maiden voyage in that pretty camper. My Colorado is the old style...not the newer bigger trucks. 2010... it has the 3.5L 5-cylinder motor in it and has been a very good truck. I'm considering a full size truck but have got this for now. I'll let you know how it goes. Good luck in the Colorado. Good trucks, especially the newer ones. Keep us posted and most of all HAVE FUN.
Post by mel on Apr 27, 2018 3:44:26 GMT -8
So we sold my husbands Jeep Liberty a few weeks ago. I called on two chevy colorados I wanted to look at and they both sold that same day :/ So for about 3 weeks I have been searching for something. The other day day I saw a gmc canyon pop up with low miles so yesterday we drove 3 hours to get it. Excited we found what we were looking for. It has a 3.7L 5cy engine with factory tow package and I plan to add a break controller eventually. Apparently the one we bought 2008 is rated for 5500 pounds which I have trouble believing out of a 5cy. I had previously looked up 04-06 5cy 3.5L models because that is what I was finding in my price range. And those are rated for 4000lbs so I figured this one was too. I guess in 08-12 they changed the engine from 5cy 3.5L to 5cy 3.7L Which to me doesnt say hey I can pull 1500 more pounds. I will never have anything heaver than my airflyte. But I found that interesting. Anyways I will stop rambling my random thoughts now. IMG_3406 by Mel L, on Flickr IMG_3407 by Mel L, on Flickr
Post by vikx on Apr 27, 2018 21:17:16 GMT -8
Congrats on the truck! I think manufacturers sometimes list what the motor/drivetrain is capable of rather than how the vehicle actually tows the trailer.
Ford Explorers come to mind. They were well rated (I believe at 5K?) but also tended to get out of control and flip over. They just didn't have the wheel base and weight to tow that much.
I think your new truck will be fine and love the extra little cab portion.
ktsame
1969 Frolic
Post by ktsame on Apr 28, 2018 9:16:44 GMT -8
Somewhat off topic but what is the difference between sway bars and load levelers? I thought I had sway bars but was told they are load levelers.
Thanks, Kathy
Post by vikx on Apr 28, 2018 10:52:14 GMT -8
The terms "Load levelers" and "Weight distribution system" are often used interchangeably. However, load levelers can be air shocks or beefed up suspension rather than a hitch system.
A Weight Distribution System consists of two bars and a ball mount hitch piece. They adjust the way a vehicle rides so that the it stays level when towing. In other words, the front of the vehicle doesn't lift with the added trailer weight at the back. Many of our vintage trailers are light enough not to need them. Also, the bars and hitch are very heavy. They may come with a sway bar.
A sway bar dampens the tendency of the trailer to sway in wind or when a large truck passes. Most work on adjustable friction to limit sway. There are quite a few types, some quite elaborate.
I've used a simple sway bar with larger trailers and have been very happy with the result. Haven't needed the WD system.
RinTin
Post by RinTin on Apr 28, 2018 12:41:22 GMT -8
Another factor to keep in mind is that smaller, narrower towing vehicles will restrict your rear vision. While each U.S. State has their own laws, generally speaking, your mirrors should reflect a clear vision of 200' of the highway behind you. Few, if any, smaller vehicles can do so with stock factory mirrors.
Post by bigbill on Apr 28, 2018 17:06:27 GMT -8
Another factor to keep in mind is that smaller, narrower towing vehicles will restrict your rear vision. While each U.S. State has their own laws, generally speaking, your mirrors should reflect a clear vision of 200' of the highway behind you. Few, if any, smaller vehicles can do so with stock factory mirrors. Thanks for reminding them. I have been preaching mirrors for years, not only is it the law, it is needed to stay alive when changing lanes turning, backing up, ect. The are even nice to give you a chance to see problems with your trailer, like tires losing tread,or doors flying open and other things happening. This is why I always suggest before buying a tow vehicle back it up to your/A trailer as if you were hitching it up and check your rear vision. Is it OK or can it be solved with mirror extensions, if not consider a different tow vehicle, your families life could depend on it.
Post by bigbill on Apr 28, 2018 17:22:38 GMT -8
I realize that we all would like to buy a $100.00 truck that would tow our trailers over the tallest mountain and across the hottest desert while getting 50 mpg but remember to pick a tow vehicle that will do it safely. YOUR FAMILIES LIFE DEPENDS ON IT. Also did you ever wonder why some people enjoy their travel trailer vacation and other say never again. If your rig doesn't sway in the wind and you can see well enough to be comfortable plus not have to worry if it will get up or down a hill or even make it back home you will probably be one who enjoyed their vacation. I'm not saying you have to buy a brand new crew cab dually just something that you can use comfortably. There are a lot of low mileage older tow vehicles out there that can be bought reasonable, take the time to make the best decision for you. May God be with you in your hunt.
Post by danrhodes on Apr 29, 2018 15:21:52 GMT -8
Nice truck. I've seen a ton of those around my city lately. Good competition for the Tacoma that is coasting on it's former reputation.
windborn
1957 Sportcraft 15
Post by windborn on May 8, 2018 19:36:28 GMT -8
Looks like I'm too late, but figured I'd chime in anyway in case someone is reading through this for advice one day. I'm a user that tows with smaller vehicles.
Last year I towed my small camper from Eastern MA to Far West TX and back with a V6 Mazda Tribute rated at 3,500lbs. I made it, but had to give up on that car by the time I got back. Even though my trailer only weighs 1,200lbs, that little thing was struggling and that trip did it in.
I replaced it with a V6 4Runner rated for 5,000lbs, which is still smaller than what most people tow with on here. But the drive from MA to TX was incredibly easier this year. One of the biggest differences has been the longer wheelbase and heavier weight: the trailer sways so much less. With the smaller vehicle I was on edge everytime a truck drove by.
So towing with smaller SUVs long-distance is definitely possible, you just need to be comfortable taking it a little slower.
Post by bigbill on May 9, 2018 13:23:13 GMT -8
Windborn Us exactly right all most anything will pull a trailer. With that said the thing you have to decide is as follows: 1 Do you care if it breaksdown 2 Do you care how comfortable you are 3 Do you care if it will stop in an emergency situation 4 Do you care if it slows down to ten miles per hour on hills 5 Do you care if a strong gust wind blows you off the road killing all or part of your family 6 Do you care if you are arrested for driving an unsafe vehicle This list could go on but by now you have food for thought. Please select a vehicle designed to do what you need it to do. Be safe and enjoy the wonderful world of camping.
