CorvettCrzy
'58 Corvette, '64 Franklin
Post by CorvettCrzy on Mar 13, 2018 17:10:07 GMT -8
So I purchased seal for my rear window (I'm sure) and because of the qty. I'm kind of thinking the front too from VTS. I also bought some of this gutter seal stuff too. Window seal by Corvett crzy, on Flickr The problem is....that was 4 years ago. I feel really confident that I bought the right seal and that I used the original to make that purchase but it's long gone now. I cannot for remember where this seal is supposed to go. Does anyone have any pictures of the installation of this black seal and why I might have purchased the seal. (I'm pretty sure that purchase was suggested by a member of either this forum or the repairing trailers forum.
Post by vikx on Mar 13, 2018 20:10:57 GMT -8
It goes around the frame flange on both sides and the bottom. The bulb part helps seal the window as it closes. The top flange has putty and screws, no seal.
I use a little bit of gasket glue for installation, but it doesn't stick very well. It's a bit difficult to install the screws in the bottom and sides, the glue helps hold the gasket as you do that.
