flyte 1959
1959 shasta airflyte
Post by flyte 1959 on Nov 10, 2013 14:46:58 GMT -8
anyone know the floor thickness on a 59 shasta? forgot to check it before the floor got pulled up. thanks
Post by vikx on Nov 10, 2013 22:16:40 GMT -8
I believe my 57 was 5/8, definitely not 3/4... A lot of trailers are 1/2 inch with quarter inch overlayment. Makes for a nice smooth surface for your flooring.
Post by mobiltec on Nov 15, 2013 16:35:58 GMT -8
I have a 59 but have not got to the point of doing anything with the floor yet. But over the weekend I can let you know because I need to drill a hole in the floor anyhow. It's got a layer of Cellotex between the plywood and the framing. That is usually half inch. The plywood is going to be either 3/8 or 1/2 inch. Will let you know.
I am no longer leaving the Cellotex in when I replace the floors. I'm just using what ever thickness plywood that will flush up with the existing floor. 7/8 inch or one inch total thickness. The Cellotex squishes over time and that is what gives you that floating frame thing in the front where the whole box moves up and down separate from the frame.
Post by mobiltec on Nov 19, 2013 16:03:29 GMT -8
The best I can tell, without glue and flooring material, tiles in my case, the floor is a total thickness of one inch. Half inch Cellotex and half inch plywood. That's a full 1/8 inch thicker than the 57 I did.
Post by cowcharge on Nov 20, 2013 14:58:29 GMT -8
Mine was just linoleum over half-inch ply, and not enough frame under it either.
moonshiner
Post by moonshiner on Dec 1, 2013 22:23:44 GMT -8
can any one tell me where I can find the molding that ties the flooring to the rear exterior wall for a 68 Aristocrat? It is similar to the bulk wallhead molding "F" shaped on VTS however is not the same? anyone ?
