paxtonshasta
http://paxtonshasta.blogspot.com/2012/02/what-did-we-do.html
1962 Shasta
Post by paxtonshasta on Jan 25, 2018 8:28:03 GMT -8
I am going to be looking for a new tow vehicle soon, but I have a few questions. I have a 1962 Shasta Airflyte 16ft that we did a restomod on. I had a Dodge Ram that pulled and stopped no problem (w/o trailer brakes) with a painful 10mpg. Now, we are looking to have 1 vehicle to use as a family, and pull the camper, so likely an SUV preferably with batter mpg than the Ram was. 1. Anyone know the starting weight on this Shasta model? (Ballpark weight?) 2. Could I pull it with a Honda Pilot? 3. How hard to get the trailer brakes tested and running?
Thanks in advance for all your help!
Post by bigbill on Jan 25, 2018 8:39:57 GMT -8
vehicles same year same model can have different tow ratings. Check with your dealer for info on the one you have or wish to purchase. they will need the vin/serial number to look it up. I think a 5000 lb tow load would be the very minimum I would consider and more is better. I prefer a tow rating at least twice the total weight of the fully loaded trailer. Remember many vehicles include the weight of passengers and cargo in the vehicle into their total towing weight. So a 500 pound mother in law and two Bull Mastiffs going along can make a huge difference, not to mention ten kids.
Post by bigbill on Jan 25, 2018 8:51:11 GMT -8
As to your question about what it takes to get working trailer brakes that is a totally impossible question to answer not knowing what you have now. Will you need a brake controller for the vehicle, can you install it yourself or pay somebody else. Are the trailer brakes all there and in good working order or does everything need replaced then who is going to do it. With the information I have right now I would guess somewhere between $5.00 and a $1000.00. Not trying to be a smart a** just no way to give you an honest answer.
Deleted
Post by Deleted on Jan 25, 2018 11:35:41 GMT -8
Hi Paxtonshasta. Can you post a photo of that Airflyte? We are all interested to see what you have, and I'm particularly intrigued by your "restomod" comment. I'm planning something like this for my trailer and would like to see what you've done.
Regarding the tow vehicle, a friend of mine has a 2017 Pilot and pulls a large Ranger boat that is pushing 3000 pounds. He has the 3.5L V-6 with all wheel drive. This has 5000 pounds towing capacity versus the 3500 pound 2 wheel drive. You might be able to get by with the 2 wheel drive, but I believe it's only a couple grand to upgrade to AWD. So in my opinion, go with the AWD.
The buddy of mine pulls his large boat like it's not even there. Works a lot better than my heavier Silverado and I have to put mine in 4 wheel drive when on boat ramps.
The weight of your trailer fully loaded (wet) should be somewhat less than 3000 pounds I believe. Someone else on this forum might give you a better estimate.
Regarding trailer brakes. My opinion is that they are not needed with a new tow vehicle these days. The larger disc brakes, ABS, traction control, etc. is light years ahead of the older cars that pulled these trailers in yesteryear.
I'm not sure what bigbill was referring to with "controller" for your vehicle? Maybe he can clarify? I believe the trailer would have a tongue actuated hydraulic brake system, but I might be wrong. Do you know for sure what you have?
paxtonshasta
1962 Shasta
Post by paxtonshasta on Jan 25, 2018 13:13:41 GMT -8
Thanks everyone for the info. As to the brakes I realize that’s an open question, but I guess I was wondering what experiences others have had with their vintage trailers in testing and repairing their brakes. Maybe they work fine right away or magnets or springs busted, parts easily available, replace entire assembly?, etc... My brakes haven’t been used in decades. We chose not to do a resoration back to original, we tried to keep it “inspired” by the original design, but updated some systems and generally customized it for us. Plus since it was nearly an gut job on the interior, we had some freedom to make changes. You can see pics and read about it here.... paxtonshasta.blogspot.com/2012/02/what-did-we-do.htmlI will probably get a standard brake controller and not a intelli-hitch type Setup. We took a road trip a few years ago and the re-fueling was killing me with the Dodge Ram, so I am hoping to find something a lil more wallet friendly.
Teachndad
1955 Rod and Reel
Post by Teachndad on Jan 25, 2018 15:27:08 GMT -8
We took a road trip a few years ago and the re-fueling was killing me with the Dodge Ram, so I am hoping to find something a lil more wallet friendly.  Hi, I have a 2012 HOnda Ridgeline. Towing capacity is 5,000 lbs. Techology in it is from 2006. So, it's got old tech in it. It pulls a 17.5' 2200 lbs. trailer and gets typically about 14 mpg towing at 55 mph. If it's really flat, I can get to 16 mpg. Not great, not awful either. The newer larger trucks I THINK, get better gas mileage when towing than that, have more horsepower and torque. But A new full size truck can cost $$$. Depends on your budget. Check out the Honda Pilot forums. I was researching Pilots when I was looking for a new TV. I got the pick up because the wheel base was longer and the first gen Ridge was more just designed for towing, than the Pilot. But, people do tow with those. Rod
1962 Forester- 1959 Shasta
Post by nccamper on Jan 25, 2018 15:38:31 GMT -8
An early 60s Airflyte weighs about 1800 pounds empty and dry. oldtrailer.com/vintage-shasta-airflyte-trailer-specs.htmlTowing is a rolling debate with a lot of varying opinions. I’ll give you mine. I’ve towed with a small truck (Ranger V6) with a towing capacity of 3600 pounds and didn’t like it at all in the mountains. On the open plains it was fine but the fact that it was light weight (for a truck) with less wheel base made towing in a heavy wind a white knuckle experience. In the Rockies it would slow down to a crawl uphill even with my foot to the floor. I like towing in the mountains and I want towing to be stress free. For me, that means day-to-day lower gas mileage and driving a bigger truck than I wanted originally. On a side note, we wanted to take 2 chairs, a small folding table, spare tire, tool boxes, bins with firewood, porta-potty, door mat, small BBQ, cooler, etc, etc, in the tow vehicle plus have space for 4 adults to travel comfortably. That also means big with lower gas mileage. Oddly, our new truck with three times the tow capacity gets the same mpg as our smaller truck when towing. But when not towing it gets much less the mpg. So do you want better MPG day-to-day or space, weight and power? You have to decide what’s important to you.
Post by bigbill on Jan 25, 2018 17:24:37 GMT -8
bw All of the shastas I have been associated with had electric brakes which needs a controller on tow vehicle to work. As for brakes if you are in a state that requires brakes and don't have them you could be found liable even if the accident wasn't your fault.
Speaking of modern technology many law enforcement agencies now have special accident investigation teams that are trained to inspect everything on all vehicles involved. I'm not saying you have to buy a given type of vehicle, but I am saying make certain what you are buying will safely do the job you desire. Some people have no fear of a trailer jerking their vehicle around, some are terrified of it.
I probably have more experience towing all types of trailers than most people, everything from small cement mixers to gasoline tankers, pop-ups to lowboys hauling heavy equipment. My knowledge of law enforcement came from a little school called Ohio State.
The main thing is make sure if you spend the dollars that any new vehicle cost today make sure that you and your family will be happy with it. The wrong choice can be very expensive or might cause the family to decide to never go away with a trailer again. The third possibility is all or part of the family never lives to talk about.
My advice is read everything you can make a decision and be prepared to live with it. HAVE FUN AND HAPPY CAMPING
Deleted
Post by Deleted on Jan 25, 2018 17:37:16 GMT -8
Thanks bigbill on the Shasta clarification. I have (2) non-Shastas from that same vintage and they both have the tongue actuated hydraulic type. Which is kind of nice so I don't have to worry about the controller issue, and the folks I might ultimately sell them to wouldn't have to worry either.
In Minnesota, the requirement for brakes is 3000 pounds and there is legislation being considered to increase that to 5000 due to the improved braking technology of the modern vehicle. That would only be allowed if the vehicle itself weighs as much or more than 5000 pounds. Sorry to hear if it is quite a bit lower in your state.
Post by vikx on Jan 25, 2018 20:23:02 GMT -8
Tongue actuated hydraulic brake controllers are called "Surge Brakes". They worked well in the day but can be a pain to back up, as the brakes are ON when backing.
Surge brakes are VERY difficult to repair and sometimes parts are unavailable. I've done two and neither was fun. Finding a new master cylinder is usually the key. There is a small brass swivel fitting on the master, be SURE you don't ruin it! They are not made any more. The swivel allows the hydraulic line to fit closer to the master cyl. body so that the cover will fit.
A "controller" is simply an electronic device to adjust or activate electric trailer brakes. Tekonsha is one brand. Most of our trailers have electric brakes if they have them at all.
Deleted
Post by Deleted on Jan 25, 2018 20:32:50 GMT -8
Thanks Vikx for the advice. I had surge brakes on a large pontoon trailer and they worked perfectly fine. Not sure if I can retrofit stuff from large boat trailers up here (and there are many), to work on travel trailers, but that may be an option. I have electric brakes on my current boat trailer, and they work fine as well. I believe good maintenance is the key to any system that is out there.
Post by bigbill on Jan 26, 2018 9:09:03 GMT -8
bw I have owned many trailers with surge brakes, but never on a camper. I build my car trailers with surge brakes and the backing up on uneven surfaces can be a pain so I always drilled a hole in the coupler to insert a lock out pin but you have to remember to remove pin before you take off. The down fall of surge brakes is in the mountains on a long down grade the wait of the trailer keeps the brakes engaged heat builds up and brake fad occurres when you need them the most. When you compare boat and open car trailers to a camper they are two different animals because of wind resistance and balance/center of gravity. I have seen many more accidents involving campers than boats. As I mentioned I built a lot of car trailers with surge brakes for the reason that car nuts tend to loan their trailer to a friend and he doesn't have a controller so no brakes if trailer has electric brakes. Both systems have advantages and disadvantages depending on what type of trailer they are being used on. If you are traveling in different states there are books that have trailer requirements for each state. If you get involved in an accident you better be in compliance with the laws of that state. I always check if I am going to be pulling through a state I'm not familiar with. The brake weights, maximum towing speed, and anything else that might be different. I also check CCW laws before traveling. In the last 3/4 of a century this practice has helped me avoid any disruptions to my travels. I have been all over the United states and Canada and wouldn't trade my memories for anything. when we go on vacation now we like to avoid the interstates and travel the old two lanes to see the country and meet the people, it tickles me when someone says they don't like to travel by car because interstates are boring. They don't know what they are missing by not using the state highways through the towns and villages of our great country.
Deleted
Post by Deleted on Jan 26, 2018 10:54:32 GMT -8
Thanks bigbill for reinforcing the safety aspect of this venture. That has to be the 1st priority in everything we do. Especially when it comes to electrical systems, and this great discussion on towing. For reference, here's a couple shots of the tongue on my 1965 Winnebago constructed with surge brakes:
Post by bigbill on Jan 26, 2018 18:45:45 GMT -8
that appears to be an old Atwood surge unit. most of then used ford master cyls. If you need a new one make certain the bore is the same size for it to work as designed. If that unit is working properly you shouldn't be able to back it up over any type of resistance even soft dirt. when I was installing them back in the day I drilled a hole so that I could insert a pin when in the unlocked position allowing me to back up without activating the brakes. Usually a piece of 1/4" drill rod.
Deleted
Post by Deleted on Jan 26, 2018 19:12:50 GMT -8
Thanks Bigbill...I'll keep that in mind when I get to restoring this trailer. My plan is for a complete frame off for this one, so I'll be able to get a real close look at all the individual axle and brake components in addition to the master cylinder and hydraulic lines.
