Post by bigbill on Feb 7, 2018 8:54:51 GMT -8
In regard to my above post I use the ones with two blades that move in opposite directions and are held together with a small pin near the tip. Not a single blade or a rotary blade.
Post by mobiltec on Feb 7, 2018 8:59:12 GMT -8
In regard to my above post I use the ones with two blades that move in opposite directions and are held together with a small pin near the tip. Not a single blade or a rotary blade. Yes Bill. That's what I'm talking about. Two reciprocating blades.
Post by bigbill on Feb 7, 2018 9:07:44 GMT -8
In regard to my above post I use the ones with two blades that move in opposite directions and are held together with a small pin near the tip. Not a single blade or a rotary blade. Yes Bill. That's what I'm talking about. Two reciprocating blades. Yep I know what type you use I was just clarifying what we were talking about. If my poor old feeble mind is serving me right we have covered this multiple times in other post over the years.
Post by mobiltec on Feb 7, 2018 9:38:28 GMT -8
Yes Bill. That's what I'm talking about. Two reciprocating blades. Yep I know what type you use I was just clarifying what we were talking about. If my poor old feeble mind is serving me right we have covered this multiple times in other post over the years. Yep. Just like all the other subjects.
Post by vikx on Feb 7, 2018 11:44:24 GMT -8
Yes, the electric knife doesn't cut as described. I'm not getting a straight cut and it tends to hang up without cutting. Maybe I'm going too fast??
Post by mobiltec on Feb 7, 2018 13:01:56 GMT -8
Yes, the electric knife doesn't cut as described. I'm not getting a straight cut and it tends to hang up without cutting. Maybe I'm going too fast?? Does yours have two blades that work against each other?
Post by bigbill on Feb 7, 2018 14:48:32 GMT -8
Maybe they need sharpened. Maybe the motor is wore out and moving to slow. Maybe the knife just don't like you  . I never force it, just allow the knife to do the work.
Post by mobiltec on Feb 7, 2018 14:53:35 GMT -8
Head to the thrift store and get another one.
Post by vikx on Feb 7, 2018 19:16:16 GMT -8
There are two blades and they feel sharp... At least they did when I cut my thumb. I'll do some experimental cuts and see if I can learn. This is not something I like to do.
Post by mobiltec on Feb 8, 2018 6:01:19 GMT -8
I used a felt tip pen to mark the foam and then just begin cutting.
Post by vikx on Mar 14, 2019 20:36:00 GMT -8
The knife cuts turkey just fine... not foam rubber tho.
