idaho211
30 amp
Sept 12, 2017 21:50:23 GMT -8
Post by idaho211 on Sept 12, 2017 21:50:23 GMT -8
So here is my breaker box inside. Question, neutral bar on left and ground bar on right? Here is a diagram of the trailer wiring. {\rtf1\ansi\ansicpg1252 {\fonttbl\f0\fnil\fcharset0 .HelveticaNeueInterface-M3;} {\colortbl;\red255\green255\blue255;\red0\green0\blue0;\red255\green255\blue255;} \deftab720 \pard\pardeftab720\sl480\qc\partightenfactor0 \f0\fs40 \cf2 \cb3 \expnd0\expndtw0\kerning0 \outl0\strokewidth0 \strokec2 IMG_2181 } {\rtf1\ansi\ansicpg1252 {\fonttbl\f0\fnil\fcharset0 .HelveticaNeueInterface-M3;} {\colortbl;\red255\green255\blue255;\red0\green0\blue0;\red255\green255\blue255;} \deftab720 \pard\pardeftab720\sl480\qc\partightenfactor0 \f0\fs40 \cf2 \cb3 \expnd0\expndtw0\kerning0 \outl0\strokewidth0 \strokec2 IMG_2on Flickr\ }
30 amp
Sept 12, 2017 22:55:52 GMT -8
Post by vikx on Sept 12, 2017 22:55:52 GMT -8
From the photo, it appears that the neutral/common bar is on the left with the white wires.
The Ground bar is on the right? Very hard to see. It should be attached to the metal box, metal to metal. The frame ground should be in the bar, as well as other circuit grounds. I'm assuming the silverish metal wire is the aluminum frame ground.
