61 Shasta
Post by 61 Shasta on Oct 15, 2013 18:41:16 GMT -8
As many of you know, cleaning and repairing these jalousie windows can be a test of endurance and patience. In doing mine I injected a couple of tricks and idea's that I will pass along. I found a cleaning product a few years ago that I have found to be superior to anything else I have tried. I got it from a local window shop that has since gone out of business. I am now out of it and had to find a new source. It is kind of expensive and difficult to find but well worth the expense and effort. It is wholesaled though CRL CR Laurence company. I went on line and found a vendor who handles it and will be purchasing it from them. Their website is very good and easy to navigate. This stuff will make water spots disappear in a wink. Not saying it doesn't take a little elbow grease but it really works and I recommend it highly. Window before: Window after installed:
61 Shasta
Post by 61 Shasta on Oct 15, 2013 18:53:55 GMT -8
Now, I had a heck of a time installing the little felt strips along the edges of the window. I couldn't push them in because they wouldn't go past the window operators. What to do. Well, being a fisherman I had some 17 lb. mono line around so I took a needle and threaded it into one end then just pulled it through to make a double loop. I then lubed the channel with some clear silicon lube with a Q-tip. I then started the felt strip into the channel, placed the fishing line down into the channel behind the window operators and pulled. What do you know! It came right through!!!. I couldn't pull it all the way up with the line so I removed the line and finished pulling it up with my needle nose pliers. I will say, I had to use my hair clippers to remove some of the felt as the first effort failed because the felt was too long and wouldn't let my window close. I didn't take much off, just enough to let them work. Finished window: Felt strip: So now that the windows are done I'm taking tomorrow off from my project and going fishing for steelhead and salmon in our beautiful Columbia river. Hope I have as much luck with that line as I did with this one.
Post by mobiltec on Oct 15, 2013 19:04:44 GMT -8
Way cool! Hoo Rah on both...
gladeslvr
Post by gladeslvr on Nov 2, 2013 16:55:17 GMT -8
Wow, that window looks great! Tackling my jalousies is going to probably wait until the Spring, now...good job!
Post by mobiltec on Nov 13, 2013 20:01:05 GMT -8
Wow, that window looks great! Tackling my jalousies is going to probably wait until the Spring, now...good job! Why wait? It's something you can do inside in your spare time. Take one window out, seal up the hole with some plastic or something and take it inside and work on it there. Lots of little jobs you can do during the winter like using steel wool to polish the gas lamp or the door latch. Stuff like that.
Post by SusieQ on Nov 13, 2013 20:16:50 GMT -8
One of my windows has a pane missing. My kitchen window has all of the panes but they are loose and slide out the bottom. I had to duct tape them to tow it to make sure I didn't lose them. I wasn't sure what I was going to do about permanently securing the panes. I originally thought about taking them to a glass shop or having them come to me. Should they not be caulked in the channels that hold them in?
Post by mobiltec on Nov 13, 2013 20:28:24 GMT -8
VTS sells the little rubber discs that hold the panes in. There is a great tutorial here on Jalousie windows and I have a video somewhere on my website.
Post by SusieQ on Nov 13, 2013 20:33:55 GMT -8
VTS sells the little rubber discs that hold the panes in. There is a great tutorial here on Jalousie windows and I have a video somewhere on my website. Thanks, I will look for it. I figure that's going to be one of my easier projects. And I am to the point now that I have read so much and looked at so many pics that I'm having memory lapses as to where I've read what. I've tried to bookmark things as I've found them but haven't been so good at it. I sure do appreciate your help.
