Post by ladywendolyn on Mar 25, 2017 20:31:27 GMT -8
A lot of ladies who have little trailers seem to like the vintage train cases. It gives you something to haul your make up in to the shower room, plus you can put the train case out on a shelf because it is so cute. The only problem is that they are often smelly due to age. However, it is very easy to restore them with new fabric. Here is a photo of two that I restored recently for a vintage sale. (The gold one is original). The insides had horrible, stained old fabric. All you need in order to restore them are the following supplies: -1/2 yard of cute fabric -2 pieces of poster board, plus one slightly thicker piece of cardboard from a box. - spray glue adhesive -tacky craft glue -hot glue #1 Simply strip the old fabric and cardboard out and trace it onto new cardboard. I usually use a thicker piece of cardboard for the top as I want to install some 1/4 inch staples to hold a mirror in place. #2 Figure out how to lay out the new cardboard shapes on your fabric so that they fit. Cut around the cardboard shapes leaving about a 1 inch overlap. (Note, often one piece of fabric bridges the top and bottom section, so leave extra fabric for that. #3 spray one side of the cardboard with spray glue adhesive lay it on the fabric and smooth it out. Do one pice at a time. #4 Fold over the excess fabric and adhere that with tacky craft glue. It sticks instantly. #5 Once pieces are glued and ready, I recommend assembling the case dry, so that you can see which pieces should go in which order. Usually the bridge piece between the top and bottom goes party under the top piece. #6 Now hot glue the various pieces into place and your done..
Post by mrmarty51 on Mar 26, 2017 13:04:50 GMT -8
WYYYY knock me out. I had a couple of those. I think that they went to the St. Vincent Depaul store.
Post by Hamlet on Mar 27, 2017 10:30:43 GMT -8
I love the little red one. Trying to think of 1) where I could keep it in Hamlet and 2) what I'd use it for. By the time I figure it out, I will have found one or two in a thrift store somewhere!
Post by ladywendolyn on Mar 27, 2017 11:50:41 GMT -8
Some people keep pet supplies in them, or underwear or whatever. I am keeping mine on the rear shelf, or next to the rear gaucho on the wheel well table. I will tuck it under the bed at night..
65callie
Post by 65callie on Mar 27, 2017 17:31:46 GMT -8
I have 2 train cases in my Shasta. I keep tools in the one that has a tray, and use the other one for the packing meds, first aid supplies and other personal things.
Post by vikx on Mar 27, 2017 20:15:11 GMT -8
I have several. One is full of tin snips, the next Dremels and parts, another vise grips. You get my drift...
Maybe I should offer them at the next rally. Empty, of course.
