Post by vulcancowboy on Oct 5, 2013 11:32:28 GMT -8
I think I have finally gotten rid of all of the rotted wood and am ready to start the rebuilding. I noticed when I removed a section of the floor in the rear of the trailer, that the 3 wooden frame members that the plywood floor is attached to, are not connected to the metal frame. I am tempted to use some carriage bolts to connect the wooden framework to the metal framework. What do you think?
Post by cowcharge on Oct 16, 2013 5:02:30 GMT -8
You've probably already done what you decided by now, but I'd have added more bolts. Can't imagine why they didn't use any.
Post by vulcancowboy on Oct 16, 2013 13:07:39 GMT -8
You've probably already done what you decided by now, but I'd have added more bolts. Can't imagine why they didn't use any. Yeah, I have figured it out, after posting this picture, I found where 2 bolts went through the angle iron that runs side to side. I did think about adding another bolt, but decided against it, although for the life of me, I can't remember why?
