gary350
1964 FAN
Post by gary350 on Mar 13, 2017 5:43:31 GMT -8
Post by nccamper on Mar 13, 2017 19:04:59 GMT -8
I started one once and it does put out a lot of heat. Mine really had only two setting...cook or broil.
My understanding is that it really goes through gas quickly verses the Wave3 or 6.
Post by mrmarty51 on Mar 13, 2017 21:01:51 GMT -8
I would not install it in a camper. With the roof vent, raining, going down the road, might fill the furnace with water. She small furnaces made for campers, if You look around, You will find a lot of them are direct vent. They have a double wall stove pipe. Hot exhaust goes out the inner pipe and fresh air for combustion comes in the outer pipe so they are about a zero clearance and, they do not burn air that has already been heated. I would say that the direct vent heaters must be about 80% or even higher on efficiency. At least the direct vent eater in My house is about 85% energy efficient. The direct vent camper stoves exhausts and intakes out the side of the trailer. The non direct vent heater would consume a lot of the available oxygen in a camper rather quickly, unless You have a window open a ways.
