aaronchuck
Trailer: 1964 Thunderbolt
Post by aaronchuck on Jan 21, 2017 0:02:39 GMT -8
Hello all, so I have this 1964 Thunderbolt trailer. The 15A 125V 2-Pole, 3-Wire Weatherproof Inlet was working fine till today. I think the prongs are just moving a bit much and the thing is obviously old. I searched around for a new one and did manage to find plenty online. However, it occurs to me that it may not be what I need going forward if I want to plug in, in general, at RV parks. WHat are your recommendations? What should I actually purchase and connect to this thing? The only thing it powers are some interior lights. There's no fridge, just an icebox. Even if I get a fridge, it will be a 3-way that I'll run on propane and the solar I will be installing. I grabbed photos with my iphone, but I can't figure out how to upload images to this page, other than the clunky and arcane URL way. I don't have images stored online that way. Is there no ability to simply attach images to a post? If so, I don't see it anywhere. Thanks in advance. Aaron
Post by danrhodes on Jan 21, 2017 13:38:26 GMT -8
aaronchuck
Post by aaronchuck on Jan 21, 2017 14:22:46 GMT -8
That's the exact one I was looking at getting as replacement, but then I wondered how I plug in at an RV park. These guys sell them as well. Been buying from them quite a bit. www.vintagetrailersupply.com/15-Amp-Inlet-Residential-Grade-p/vts-2257.htmFor now it would be great while Im working in the garage. IS there an adaptor cord or something would need if I install the 15A Leviton, or should I not install that and go with something else, then get an adaptor for plugging into garage? Thanks for the help!
Post by Ten on Jan 21, 2017 14:45:56 GMT -8
With a 15 amp service, you should not need anything special to plug in. It would be a standard three-wire cord, such as a heavy extension cord, plugged in to a regular 110-volt outlet. There are ways to make it better if you are upgrading it later. For now though, the replacement plug should work fine.
aaronchuck
Post by aaronchuck on Jan 21, 2017 15:53:47 GMT -8
With a 15 amp service, you should not need anything special to plug in. It would be a standard three-wire cord, such as a heavy extension cord, plugged in to a regular 110-volt outlet. There are ways to make it better if you are upgrading it later. For now though, the replacement plug should work fine. I see. So all RV parks do have regular household type outlets. I guess I thought they were special types only and that I Would need to get a different inlet for my trailer. Seems like I habve no need to change anything roght now then...well, aside from replacing this really old 15A inlet. My only concern is having shore power for the 2 60watt interior lights. There is no other electrical. Anything else I plan on using electric for such as charging all my photo gear, small coffee grinder, rope lights for awning and possibly a 3-way fridge, I'll be powering with solar. This was really helpfull. Thanks guys!
Post by danrhodes on Jan 21, 2017 18:54:13 GMT -8
My camper also came with the 30A to 15A style cord, so you could hook up to a site that didn't have the standard outlet... Adapters are also available.
aaronchuck
Post by aaronchuck on Jan 21, 2017 20:30:30 GMT -8
Post by vikx on Jan 21, 2017 20:55:15 GMT -8
That adapter will work. Handy to have sometimes...
Post by danrhodes on Jan 21, 2017 21:47:07 GMT -8
aaronchuck
Post by aaronchuck on Jan 21, 2017 22:46:32 GMT -8
Id prefer to support the vintage trailer guy. I just got 4 teardrop marker lights and some hubcaps. Next is that adaptor and pole and rope awning. Well, also the inlet. He has that too.
