Post by rogerthedodger on Nov 23, 2016 10:10:58 GMT -8
I have wheels that measure 4 1/2" from bolt to bolt hole center, 4 bolt pattern. Etrailer wheels measure 4" center to center. Appears I cannot use those wheels. Where can I find a wheel that will fit my drum?? Roger
Post by mel on Nov 23, 2016 10:46:02 GMT -8
That is the same size bolt pattern as my Shasta Compact. They dont make them anymore, you have to find one on ebay or craiglist. Depending on the size wheel, different kinds of old cars will have them. My compact has 13" wheel so kept searching for ford falcon and mercury comet on CL and eventually found someone selling then wheels. Which are the same size and pattern as the compact. I believe there is a list somewhere that says all the cars that have that bolt pattern.
Post by rogerthedodger on Nov 23, 2016 10:58:52 GMT -8
Thank you Mel. I saw somewhere that 4x4.5 was the same as 4x100. Is that in mm?
Post by rogerthedodger on Nov 23, 2016 11:18:38 GMT -8
Wikipedia says 4x4.5 and 4x 114.3 are the same. Maybe I can find one?
Post by rogerthedodger on Nov 23, 2016 11:19:21 GMT -8
Post by rogerthedodger on Nov 23, 2016 12:37:03 GMT -8
I did find one on eBay. Thanks again. Roger
