eggman87
Post by eggman87 on Nov 15, 2016 12:13:25 GMT -8
Hi all!
My wife and I are renovating a 1958 Shasta Airflyte. We're currently in the process of rewiring. We're not interested in installing a battery, but still want to run our fan and a few 12v lights on shire power. Every converter I've researched touts it's ability to charge batteries. So I'm curious if we can get a way with a lesser converter since we won't be charging batteries. We're going with a 30 amp service with two 15 amp circuits. Any suggestions?
Dad Rambles
62 Shasta Airflyte
Post by Dad Rambles on Nov 15, 2016 12:24:04 GMT -8
Hi all! My wife and I are renovating a 1958 Shasta Airflyte. We're currently in the process of rewiring. We're not interested in installing a battery, but still want to run our fan and a few 12v lights on shire power. Every converter I've researched touts it's ability to charge batteries. So I'm curious if we can get a way with a lesser converter since we won't be charging batteries. We're going with a 30 amp service with two 15 amp circuits. Any suggestions? It depends on what a "few" is, and what kind. LED would be very low draw. A computer power supply might even do the trick.
eggman87
Post by eggman87 on Nov 15, 2016 13:58:27 GMT -8
Hi all! My wife and I are renovating a 1958 Shasta Airflyte. We're currently in the process of rewiring. We're not interested in installing a battery, but still want to run our fan and a few 12v lights on shire power. Every converter I've researched touts it's ability to charge batteries. So I'm curious if we can get a way with a lesser converter since we won't be charging batteries. We're going with a 30 amp service with two 15 amp circuits. Any suggestions? It depends on what a "few" is, and what kind. LED would be very low draw. A computer power supply might even do the trick. We're looking at a Fantastic Fan and 2-3 Led lights.
Vintagehotdog
Hi, we are Paul and Irvina, Currently rebuilding a 12' 1958 Easy Traveler
1962 Oasis 18'
Post by Vintagehotdog on Nov 16, 2016 9:23:09 GMT -8
hairba11
Post by hairba11 on Nov 27, 2016 17:59:23 GMT -8
I put a 30 amp 12v switching power supply in my last in-bed slider $18. Needs to be able to have air get around it and not weather resistant at all. But cheap and pretty clean DC signature if you want to put a 12v car stereo in. www.ebay.com/itm/311471730042
Post by danrhodes on Dec 8, 2016 14:44:00 GMT -8
hairba11
Post by hairba11 on Dec 9, 2016 10:10:27 GMT -8
Double check a laptop supply. Most modern ones are pushing 18v. The 30 amp was probably overkill. The 30 amp fuse on the battery was what I based my purchase on. And a 10amp was only $5 less. I didn't run the fridge on it but did run the furnace blower a few nights.
