hairba11
Post by hairba11 on Mar 20, 2017 18:30:20 GMT -8
hairba11
Post by hairba11 on Mar 25, 2017 8:17:04 GMT -8
So here is the last step. The green two tone. My helper Squeak. Masked around the vintage decals And gave the fender vent a coat of Navajo White.
Post by mrmarty51 on Mar 25, 2017 9:58:29 GMT -8
That came out looking pretty nice.
Post by vikx on Mar 25, 2017 19:48:44 GMT -8
I like it too!
hairba11
Post by hairba11 on Mar 25, 2017 21:17:55 GMT -8
Thanks! I think so too. The green and off white still give it a good vintage look
hairba11
Post by hairba11 on Apr 2, 2017 17:01:01 GMT -8
Loaded it up on this lovely 70° day and brought it back home from winter storage. Almost had a stowaway. Hey Squeaker! Get off my roof!
Post by mrmarty51 on Apr 2, 2017 19:44:07 GMT -8
Now that is funny. Open the door and let it in, it might as well be comfy for the ride. LOL
hairba11
Post by hairba11 on Apr 7, 2017 10:49:13 GMT -8
So Squeak the cat had made herself at home in the camper via the roof vent. I had it popped up a couple of inches and that was all it took for her to investigate. In doing so she cracked the screen frame for the vent on her way through. A couple of quick searches turned up diddly. Newer vents have rounded corners and these are definitely square. So I dug out some 3/4x1/16" aluminum strip and picked up a pack of corner brackets. I cut the strip to length and used the miracle adhesive Shoe Goo and clamped it to the frame. Then on the top side put the corner braces on, drilled, and put bolts through. Should be bug proof, and maybe even a little more Squeak resistant.
hairba11
Post by hairba11 on May 14, 2017 14:25:57 GMT -8
Today's project was putting in a backup camera. I picked up a cheap wireless camera with monitor a while ago but didn't get around to it till now. I pulled the tail light lens off and then the base. There was a 3" hole in the siding where the wires came out. It was simple to splice in the transmitter to the reverse and ground and stuff it all in the wall and then reinstall the taillight. I screwed the camera mount to the siding below the light. The monitor came with a bracket and a flush mount. I used the latter and mounted it on the drivers visor and routed the wire above the headliner and down the A pillar trim. Getting the umbilical cord hooked to the truck and putting it in reverse turned on the camera Now there's a low definition view of some of the other projects.
rokon2813
Post by rokon2813 on Aug 27, 2017 3:20:41 GMT -8
Very nice job !!
I just picked one up that appears to be the exact model you have. Yours are the only pictures I can find with the double closets by the bed.
I have some questions if you will.
Left side vented panel in front of the propane tanks, what goes there originally ??
Mine is covered with sheet metal and is just an empty box inside.
Any idea of weight or specs?
Since it has an axle, is it considered a "trailer" and need a registration or do you remove your truck license tag and mount it on the camper??
Any help you can give would be appreciated.
rokon2813
Post by rokon2813 on Aug 27, 2017 3:44:09 GMT -8
Tried to post a picture, but it didn't work. Gotta figure that out. LOL
Post by mrmarty51 on Aug 27, 2017 11:51:24 GMT -8
Tried to post a picture, but it didn't work. Gotta figure that out. LOL Here You go rokon. And welcome to the forum. Click the link below for the tutorial. link
rokon2813
Post by rokon2813 on Aug 27, 2017 15:35:02 GMT -8
Thanks for the welcome, and the tutorial. Now to create a flickr account....
rokon2813
Post by rokon2813 on Aug 30, 2017 3:14:32 GMT -8
trikelady
Len-Dar
Post by trikelady on Mar 29, 2018 16:56:17 GMT -8
I know this is an old post but I have a similar truck camper made by Len-Dar, these campers are like a studio apartment on wheels.
