bellflower62
1962 Oasis - "Bellflower"
Post by bellflower62 on Oct 11, 2016 6:41:07 GMT -8
Hi All: I have a 62 Oasis with underslung springs that give me barely any clearance - see pic. Question: can these safely be turned into an over slung by flipping the axle? I was told this could be done...but is it wise/safe/easy? Has anyone done this - or has thoughts on doing it? I need more clearance...
chickenfarmer
1968 Fleetwing Wren
Post by chickenfarmer on Oct 11, 2016 6:50:50 GMT -8
I would repair or get new leaf springs, but you can get a kit to put the springs on top it will add about 5 inches, the axle stays in the same orientation.
Post by nccamper on Oct 11, 2016 14:22:38 GMT -8
I agree with chickenfarmer, replace them. Flipping the axle is not really safe.
Post by vikx on Oct 11, 2016 21:04:26 GMT -8
Flipping the axel is not recommended. It changes the way the tires wear.
Post by rogerthedodger on Nov 21, 2016 12:55:01 GMT -8
I must be missing something here. It looks to me like all you need to do is move the springs to the top of the axle, using the same u-bolts? Roger
