war3000
Post by war3000 on Mar 30, 2017 17:00:39 GMT -8
WOW!!! Glad I have a large dumpster... I think i'm going to find just as much rot as you did... Hang in there man, nice shop!
hairba11
Post by hairba11 on Mar 30, 2017 18:18:25 GMT -8
Looking forward to seeing the updates as this comes along!
decodan
1963 Shasta Astrodome
Post by decodan on Apr 1, 2017 4:41:13 GMT -8
Post by mrmarty51 on Apr 1, 2017 5:37:10 GMT -8
You have it coming apart now, WOW. What was the extra angle steel bracket welded to the rear bumper used for ? Nice shop too. How high is the ceiling in there ?
war3000
Post by war3000 on Apr 1, 2017 6:42:19 GMT -8
That was probably for the spare tire... nice job... I have mine scheduled to start in a couple of weeks .
decodan
Post by decodan on Apr 1, 2017 11:02:34 GMT -8
Hey, Yes it was a "home made Spare Holder" the PO welded on the bumper. I cut the bumper off. Thinking I may start from scratch and build a new frame. Looks like I paid for a pattern and title.
Shop has 12' ceiling so I can lift car projects on 2 post lift. Door is 10' x 16'.
decodan
Post by decodan on Apr 9, 2017 7:53:31 GMT -8
Baby got new shoes. Decided to upsize tires and wheels. Since I am building a new frame I decided that since I can position the axle anywhere I want the best thing to start with was a heavier set of wheels and tires. Got to get off on the right foot so to speak. Went with 8" trailer wheels rated at 2200# each and ST 225/75r15 10 ply tires rated at 2850# each. The weight of the finished project will increase due to the added features and heavier construction but should still come in under 4400 pounds.
decodan
Post by decodan on Apr 12, 2017 13:48:43 GMT -8
Got frame material today. Welding starts tomorrow.
Post by mrmarty51 on Apr 12, 2017 16:05:51 GMT -8
With using that box tubing, You will be able to haul two or three campers on that trailer. LOL
decodan
Post by decodan on Apr 13, 2017 16:20:06 GMT -8
Yea I know :~). That is a problem I have always had, overbuilding. Here it is on the way. Since I am adding a 30 gallon black water tank and larger fresh water tank and other improvements I figured the frame should be a little heavier. However, anything would be heavier than an original Shasta frame. In my opinion, the original frames were way to lightweight. I am also adding shocks to help cut down on the rocking motion.
hairba11
Post by hairba11 on Apr 13, 2017 17:04:42 GMT -8
Looking good. I wonder if anyone has detailed drawings for the various campers. By the time you're building from scratch from frame to roof a title would be the only reason to buy one. Aside from saying its a "restoration". I know Missouri just requires a highway patrol inspection on home made trailers over 16' to get a homemade trailer title. Under 16' they just create one at the dmv.
Post by mrmarty51 on Apr 13, 2017 17:27:57 GMT -8
And heavy duty it will be. LOL How do you like that Eastwood wire welder ? I wonder who makes them for Eastwood ?
decodan
Post by decodan on Apr 13, 2017 17:53:28 GMT -8
My plan from the onset was to just redo what needed to be done. But, when I started getting into this I could not go on without making some improvements but now we know what that turns into. A complete rebuild. "Have title will Travel"
I have used the mig welder for body work on a couple of car projects. It works great for 18 gauge to about 1/4". I use a Lincoln 175 square wave tig for stainless steel and heavier mild steel.
Post by mrmarty51 on Apr 13, 2017 18:20:28 GMT -8
My plan from the onset was to just redo what needed to be done. But, when I started getting into this I could not go on without making some improvements but now we know what that turns into. A complete rebuild. "Have title will Travel" I have used the mig welder for body work on a couple of car projects. It works great for 18 gauge to about 1/4". I use a Lincoln 175 square wave tig for stainless steel and heavier mild steel. OH BOY, That Lincoln Square Wave is a very nice machine. I have never welded with one, I have seen welds done with the SW welders and they are pretty. A friend, has a personal machine shop. He does a lot of gunsmithing. I seen a front sight that He had welded onto a barrel, using a SW welder. That was theee prettiest weld I have ever seen. so small of a bead that it blended the sight and the barrel as one.
decodan
Post by decodan on Apr 14, 2017 13:49:14 GMT -8
