katetothek
1971 Shasta Compact
Post by katetothek on Aug 29, 2016 18:26:48 GMT -8
Hi everyone! I'm new here and am the proud owner of a (new to me) vintage 1971 Shasta compact travel trailer, already named Sadie. I have had her in my driveway and plugged into my house so we could light her up as we get to know her with no problems. This weekend we're taking off for our first non-tent camping experience and I'm super excited. Problem is, I'm brand new to trailer ownership and am just not sure I'm understanding the finer points of hooking up to the water and electric. I have spent hours exploring the expertise on this board--thank you for sharing so much.
My trailer came with a three pronged plug, that I was told will convert my 110v trailer power to the power used at a campground. After much internet reading, I realize this is a standard 110v to 30 amp converter. Problem is, nearly every camp site was booked for Labor day and the only one I could find is a 50 amp full hook-up site. Can I buy a dog bone 50 amp to 30 amp converter, plug my handed down 30 amp to 110 volt converter into that, and then run my outside extension cord from Sadie to that 30 amp converter?
Or will we fry the system or start a fire? Is that a terrible idea? Do I need to find another site that is only 30 amps, even if that means not hooking up to water? (I cannot wait to use the sink instead of awkwardly holding a bladder over a bucket while I do dishes) Or do most full hook up sites have a choice of 30 amp or 50 amp on the campground pedestal?
My new trailer seems to be in great shape, all original, and the woman I bought her from said everything works.
Thank you in advance for your help. I'm excited about sleeping in my new trailer but nervous and overwhelmed. Tent camping is not sounding so bad next to a possible electrical fire.
Post by vikx on Aug 29, 2016 22:20:53 GMT -8
Welcome to the board Katetothek!
You can use a 50 to 30 amp adapter, then a 30 to 15 amp dogbone to connect the electrical. It is safe as long as you don't overload the trailer.
In other words, use one electrical appliance at a time. Lights are OK, but only add the coffee pot or maybe a little heater. ONE THING AT A TIME.
If you have a roof air conditioner, you can't use it with adapters. Some trailers of that era were 30 amp, so if you are plugged in without an adapter, the A/C would be OK. I'm guessing yours is 30 amp, so be sparing with the electrical and you will be fine.
A photo of the plug would help us help you.
Post by Ten on Aug 30, 2016 18:15:11 GMT -8
The breaker in the trailer will regulate the usage. It is possible to overload, but the breaker should protect it from any real danger. The way to disaster is if this situation were reversed...plugging a large modern unit with lots of electrical gizmos like A/C units and microwaves and electric toaster ovens and razors all at once would certainly overwhelm a smaller campground service. In most cases, even the older trailers with 110-volt wiring will not pose any more problems than the wiring in your tent.... Watch for heat where it shouldn't be, flickering lights, etc.
katetothek
1971 Shasta Compact
Post by katetothek on Aug 30, 2016 19:11:31 GMT -8
Thanks so much for your replies! I feel better now and think we will be good to go. We are quite minimalist as we're just stepping out of the tent, so my response to your posts was: "coffee pot? You mean I don't have to percolate over the gas Coleman?" Yahooo!!!!
Thanks again.
