Post by vikx on Mar 12, 2017 0:01:23 GMT -8
Really like that shade of green. Congrats!
sherrifriend
1967 Compact Shasta
Post by sherrifriend on Mar 12, 2017 7:32:29 GMT -8
New 12v wiring installed at the top of the curbside storage compartment. AGM battery below. Master shutoff switch inside the trailer. The socket allows me to plug in a trickle charger or solar charger. I'm interested in learning more about your power set up (as I'm still concocting my own).
htchevyii
1966 Aristocrat Lo-Liner
Post by htchevyii on Mar 12, 2017 8:13:59 GMT -8
Basically, power runs from the battery, to the master shutoff switch that is inside the trailer. Then it goes to a 50 amp self resetting breaker and to the fuse block. I wish that I bought a larger fuse block, mine only has 4 fuses. On the left is a ground block and a accessory socket. I can use the socket for a trickle charger or a solar charger. The other, unused at this time, breaker will supply power to my invertor.
Post by mrmarty51 on Mar 12, 2017 9:29:53 GMT -8
Basically, power runs from the battery, to the master shutoff switch that is inside the trailer. Then it goes to a 50 amp self resetting breaker and to the fuse block. I wish that I bought a larger fuse block, mine only has 4 fuses. On the left is a ground block and a accessory socket. I can use the socket for a trickle charger or a solar charger. The other, unused at this time, breaker will supply power to my invertor. The pigtailed bayonet style of fuses can be added onto any wires. That might be an option. I like the bayonet style fuses over the glass tube fuses, they make a better connection on the bayonet terminals and they are less inducive to corrosion, like what happens to the ends of the glass tube fuses.
Bugsy
Post by Bugsy on Mar 12, 2017 10:42:19 GMT -8
Just went through your thread!! Great work!!! Having the indoor space with a lift is awesome too!! Can't wait to see more!
htchevyii
Post by htchevyii on Mar 26, 2017 16:45:08 GMT -8
htchevyii
Post by htchevyii on Mar 26, 2017 16:50:30 GMT -8
O The Lo-Liner is slowly going back togeather. It's so time consuming cleaning and resealing the windows and getting the silicone off of every piece before reinstalling it. I can't wait to finish so that I can clean my shop! There is silicone and putty tape everywhere. I'm not even going to bother sweeping again until it's done.
htchevyii
Post by htchevyii on Apr 21, 2017 18:41:25 GMT -8
strange1
1965 Shasta Airflyte
Post by strange1 on Apr 21, 2017 20:43:21 GMT -8
This looks awesome...So can't wait to get mine to this point. A camping we will go!
htchevyii
Post by htchevyii on Apr 23, 2017 19:08:09 GMT -8
I'm calling the trailer done! The only other thing I am going to do is put it on the lift and paint the underside. Our first rally will be Trailer Fiesta in Petaluma next weekend if HWY 101 reopens. Heather had fun decorating. P
Removed the scary looking heater and made a magazine rack.
htchevyii
Post by htchevyii on Apr 23, 2017 19:18:44 GMT -8
Brown747
1971 ARISTOCRAT LO-LINER
Post by Brown747 on Apr 26, 2017 5:07:30 GMT -8
Awesome job! Get out and enjoy. Thor
htchevyii
Post by htchevyii on Apr 26, 2017 20:08:13 GMT -8
Post by mrmarty51 on Apr 26, 2017 20:41:57 GMT -8
And an excellent job of decorating She did. That is very nice. Dont go running off now that the travel trailer is finished. Please keep us posted about Your adventures. I think that is allowable. vikx`ll let us know if it is not.
Post by vikx on Apr 26, 2017 21:12:16 GMT -8
We LIKE adventures here! You can post in Tripping Talk so future travelers can find it...
