mark
Post by mark on Aug 5, 2016 6:26:56 GMT -8
I am a newbie here and I've been starting to do research on these. On the 68 or 69, were there different floor plans for these? I've been trying to look somewhere to see visually what they look like if so.. any help would be appreciated thank you ....
Post by Ten on Aug 5, 2016 20:23:37 GMT -8
Post by vikx on Aug 5, 2016 21:16:51 GMT -8
I've seen two floor plans for Loflytes. The one I like is the front kitchen, because of the large "potty" closet. A person could even add a shower as Hamlet has.
The 2nd floor plan is very similar to a Aristocrat Loliner: front dinette, side kitchen and rear sofa/bed. Both have sturdy bunks. I believe both also have a raised dinette area.
It's either one or the other with Loflytes, as the built-ins support the trailer body and frame...
mark
Post by mark on Aug 6, 2016 20:45:41 GMT -8
Thanks so much yes this is just what I wanted to see! What about the wings that I'm seeing on these? Some have some don't is that just depending on the year?
mark
Post by mark on Aug 6, 2016 20:49:39 GMT -8
Also, when they say these will fit in standard size garage is that generally the case because of the low profile or how it sits in general that makes this happen?
Post by vikx on Aug 6, 2016 23:48:21 GMT -8
Wings are often lost on Loflytes. Most had them thru the early 70s and are easily replaceable by Tyler's Wings.
The garage fit depends on the height. Not trying to be funny, but some garage clearances are higher than others...
bren
Post by bren on Sept 3, 2016 16:32:48 GMT -8
Would anyone be able to give me original dimensions for the cushions in a 72 Loflyte? And is it 4" foam that they used? Thank you.
Post by shastagirl69loflyte on Sept 15, 2016 17:52:17 GMT -8
Would anyone be able to give me original dimensions for the cushions in a 72 Loflyte? And is it 4" foam that they used? Thank you. I can get you the dimensions of a 69 Loflyte cushions if you'd like. I have mine that I need to recover. This is for the dinette in the rear of the trailer, correct?
Let me know and I'll measure.
kbman
1969 SHASTA LOFLYTE 16'
Post by kbman on Sept 22, 2016 10:56:19 GMT -8
