unclejtl
Post by unclejtl on Jun 11, 2016 7:34:55 GMT -8
hi, we just bought a 58 kenskill. I was cleaning it out and saw a sticker that on the stove that it was converted to natural gas. it is a "park model" that was used as a home, not a trailer. the propane regulator out front was removed (I have it). how do I convert it back? not sure exactly sure of the brand.
thanks
Post by vikx on Jun 11, 2016 20:59:31 GMT -8
The orifice is a different size for natural gas than propane. You will have to take the stove to a gas company to get it changed out. They will know the correct size for 11" water column.
Any other gas appliances will probably need to be switched out as well.
unclejtl
Post by unclejtl on Jun 12, 2016 5:29:20 GMT -8
do you know what the brand of my stove/oven is? maybe I can find the parts on line? I have converted dryers to cng to lp for our house in the desert. i'm just not sure of the brand. did GM really make their own appliances?
thanks
Post by vikx on Jun 12, 2016 21:45:40 GMT -8
Your oven is a Princess. Valves most likely built by Robertshaw. A Robertshaw manual was included with the stove info. Not sure on the stove top but probably the same.
I have some Robertshaw info but it's just basically how to operate the stove... Hope this helps.
unclejtl
Post by unclejtl on Jun 13, 2016 5:58:57 GMT -8
thanks!
