hcooney
Post by hcooney on Jun 9, 2016 15:38:10 GMT -8
I have an original preway four burner freestanding stove in my '55 Terry. I would love to restore it but don't know where to begin. Any directions or advice would be appreciated.
Post by vikx on Jun 9, 2016 21:29:20 GMT -8
Welcome Hcooney!
First step would be to clean it. Get all the cobwebs and rust cleaned out. You might use air pressure to clean around the burners and the oven parts.
Test each valve to see that they turn freely. I have a Preway but the oven valve is frozen. They are really pretty simple if the valves work.
Connect the stove to a LP tank with a regulator to test. Turn on the gas. If you smell propane, STOP. There is a leak somewhere. You can test the fittings with soapy solution, but I don't recommend going further without a professional inspection. If no gas smell, light one burner at a time. I've never seen a stove top fail, they usually fire right up.
The oven can be a little trickier because there are several types of oven burners, pilots and safety mechanisms. If you haven't used an older gas stove before, here again it is better to consult someone who does.
Hope this helps some. I think you should be able to check the top burners. Good Luck!
Post by vintagebruce on Jun 10, 2016 5:44:34 GMT -8
I ran across this interesting thread for people who are looking for vintage manuals and operating instructions. Looks like there is a lot of interesting info at relatively little cost. Did you know, apparently Preway manufactured the only gas dishwasher...? www.automatice.org/cgi-bin/index.cgi?showdoc~467~~SusieQ, if it will be appropriate maybe this thread could be entered in the Manuals link too.
hcooney
Post by hcooney on Jun 10, 2016 7:27:53 GMT -8
Thanks....I really just want the burners to work anyway.....Like my coffee in trailer before I face the world.
sherman56
Post by sherman56 on Apr 14, 2021 18:29:37 GMT -8
I have a '56 Preway gas stove in my Rollohome and I'm interested in how things turned out for you.
Post by vikx on Apr 14, 2021 19:56:53 GMT -8
Hcooney has not logged in since June 10, 2016...
