rvafan
Post by rvafan on Dec 27, 2016 19:11:23 GMT -8
<a href="http://s1255.photobucket.com/user/RVAFAN/media/IMG_0161_zpstsl9s2tt.png.html" target="_blank"><img src="http://i1255.photobucket.com/albums/hh622/RVAFAN/IMG_0161_zpstsl9s2tt.png" border="0" alt=" photo IMG_0161_zpstsl9s2tt.png"/></a>
You will notice this section is backwards... I had to take a picture, very funny to me. I then put the camera down and removed the screws and turned it around.
rvafan
Post by rvafan on Dec 27, 2016 19:13:17 GMT -8
Things are running smoothly now.... very time consuming but smoother and stronger. I have finished the walls, next step is the interior. Step 2 electric. Step 3 insulation. Step 4 skin.
quick question to anyone with an opinion?
I am replacing the entire ceiling and was woundering if any one else has decided not to replace the ceiling vents?
i personally don't want to cut holes in the roof!
Post by vikx on Dec 28, 2016 21:36:47 GMT -8
Frame for the vents. That way, if there's not enough ventilation and you change your mind, it will be easy. I shim every vent as well; try to get 3/4" at least. That allows good drainage so the vents don't seep.
Once framed, drill a 1/16th hole in each corner thru the ceiling panel. They are hard to see if you look and allow you to find the framing.
Many Loliners have no vent to start with; I always add the framing.
rvafan
Post by rvafan on Jan 29, 2017 11:44:03 GMT -8
The window table / work table curb side middle
rvafan
Post by rvafan on Jan 29, 2017 11:45:28 GMT -8
Curb side before the kitchen install
rvafan
Post by rvafan on Jan 29, 2017 11:46:18 GMT -8
rvafan
Post by rvafan on Jan 29, 2017 11:46:51 GMT -8
rvafan
Post by rvafan on Jan 29, 2017 11:47:26 GMT -8
Kitchen walls
rvafan
Post by rvafan on Jan 29, 2017 11:47:54 GMT -8
Work area
rvafan
Post by rvafan on Jan 29, 2017 11:48:25 GMT -8
rvafan
Post by rvafan on Jan 29, 2017 11:48:57 GMT -8
rvafan
Post by rvafan on Jan 29, 2017 11:49:25 GMT -8
Post by vikx on Jan 29, 2017 22:13:21 GMT -8
It's looking really good! Cabinets really make the whole trailer stronger. Thanks for sharing.
rvafan
Post by rvafan on Feb 15, 2017 8:04:28 GMT -8
rvafan
Post by rvafan on Feb 15, 2017 8:05:04 GMT -8
