Ziggy66
1966 Kit Companion 1500
Post by Ziggy66 on May 23, 2016 12:46:39 GMT -8
Hey everyone! I am looking for help to identify a brand and model for my forward-most side jalousie windows. I've found the model number stamp for the rear-most jalousies but I can't find anything on these. They are in great working order but I wanted to replace the seals. Talking with Vikx this morning I've come to the possible conclusion that these may be replacements for the originals as his '66 Kit has regular Hehr jalousies like at the back. These windows have 2 panes each and there is an aluminum frame around each pane. The crank handle on one of them says Phillips Industries Inc. I'm not sure if this is the manufacture of the entire window or just the crank handle... the handle is missing on the other one... Thank you in advance for any help you can provide.
Post by trailertrasher on May 23, 2016 13:38:11 GMT -8
Phillip's was a maker of windows. There are such a thing as Hehr windows,that used phillip's mechanisms too. Check the sill plate on the inside for a hehr # if none,probably a Phillips window. Vintage trailer supply carries some jalousie seals for Phillip's but not showing anything for the awning window. Your probably going to have to play match up with the seals and see if you can find a Hehr equivalent at: VTS Vintage Campesr: www.vintagecampers.com/Vintage trailer shop: www.vintagetrailershop.com/or take samples to your local Mom/Pop window shop.
Ziggy66
Post by Ziggy66 on May 23, 2016 14:42:58 GMT -8
Thank you Trailertrasher for your help!! I found this VERY helpful schematic on VintageTrailerShop.com for Hehr windows and the seal profiles for all of them!! I'm still not absolutely positive that my windows are the 3600 series but those seals match all 3 I need so I can only assume those are what I have.
