CorvettCrzy
'58 Corvette, '64 Franklin
Post by CorvettCrzy on Jan 15, 2017 14:35:25 GMT -8
I've been sitting here hunting the internet for dimension and pictures. I was lucky to find a blogger who noted dimensions on her bunk (double like yours). Using that information and looking at several pictures, it doesn't look like there is any or very little slack. I still want to research materials that people have used (even though I already purchased duck canvas) just to make sure it's ok. here is the blog link in case someone is interested, lots of other info as well kc8jwa.webs.com/shastacompact.htm
Post by mel on Jan 15, 2017 14:41:01 GMT -8
Post by mel on Jan 15, 2017 14:44:50 GMT -8
I used duck canvas on the one I sewed for my compcat. But I havent got to try it out because the compact isnt done yet. The canvas does seem like the same material that came with my airflyte if that helps.
CorvettCrzy
Post by CorvettCrzy on Jan 15, 2017 14:50:04 GMT -8
Thanks Mel, the pics you found are better than the ones I found. Yes, I think your correct. After seeing all these I've decided I'm going to make it with very little slack, just enough so that we don't have to "pull" on it to install it. I too think it'll stretch as it's used. I think the stitching and using extra strong thread are going to be key. I'm guessing that the striped canvas is most likely outdoor fabric. At least that's what it looks like to me.
Yes, the fact that the duck canvas seems the same, makes me feel much more confident that it's a good choice. Thanks again for all your help!!
Post by vikx on Jan 15, 2017 21:02:44 GMT -8
I would make the brackets a little thicker wood. If they are metal, maybe mount them on a side board so you can cut the poles shorter. The poles are particularly tight in my 57 1500..
Post by SusieQ on Jan 16, 2017 8:47:50 GMT -8
So here's my experience with the cot. I used canvas, painters canvas like you use to prevent splatter, because I had it handy and it was a good size. I measured the poles and seams and tried to make it taut. There was a little slack because I didn't measure/sew perfectly, but the canvas also stretches with weight in it. My son likes it with some slack in it; it hangs a little like a hammock and he finds that comfortable. It also comes in handy for storage but leaving it out makes it impossible to get to the cubbies above the beds. I also added pockets to the front of mine which are good for storage, too, adds some privacy but also can be in the way. I'll try to take some pics and post soon.
My son is almost 6ft tall and 130lbs and it held up well with him. I used all three poles and he liked the extra bunk area for keeping his things handy. I was really please with how well it functioned.
I used galvanized pipe, the ends are threaded and I have orange rubber covers on them that came on them and they fit very tightly in the holders. I leave the bunk up while traveling because I don't have to worry about it bouncing around causing damage. I store it in the back shelf when camping an not using it.
Post by mel on Jan 18, 2017 10:59:17 GMT -8
So here's my experience with the cot. I used canvas, painters canvas like you use to prevent splatter, because I had it handy and it was a good size. I measured the poles and seams and tried to make it taut. There was a little slack because I didn't measure/sew perfectly, but the canvas also stretches with weight in it. My son likes it with some slack in it; it hangs a little like a hammock and he finds that comfortable. It also comes in handy for storage but leaving it out makes it impossible to get to the cubbies above the beds. I also added pockets to the front of mine which are good for storage, too, adds some privacy but also can be in the way. I'll try to take some pics and post soon. My son is almost 6ft tall and 130lbs and it held up well with him. I used all three poles and he liked the extra bunk area for keeping his things handy. I was really please with how well it functioned. I used galvanized pipe, the ends are threaded and I have orange rubber covers on them that came on them and they fit very tightly in the holders. I leave the bunk up while traveling because I don't have to worry about it bouncing around causing damage. I store it in the back shelf when camping an not using it. What size poles did you buy, 1" or 3/4"??
Post by Ten on Jan 18, 2017 13:14:45 GMT -8
Post by SusieQ on Jan 18, 2017 13:48:04 GMT -8
So here's my experience with the cot. I used canvas, painters canvas like you use to prevent splatter, because I had it handy and it was a good size. I measured the poles and seams and tried to make it taut. There was a little slack because I didn't measure/sew perfectly, but the canvas also stretches with weight in it. My son likes it with some slack in it; it hangs a little like a hammock and he finds that comfortable. It also comes in handy for storage but leaving it out makes it impossible to get to the cubbies above the beds. I also added pockets to the front of mine which are good for storage, too, adds some privacy but also can be in the way. I'll try to take some pics and post soon. My son is almost 6ft tall and 130lbs and it held up well with him. I used all three poles and he liked the extra bunk area for keeping his things handy. I was really please with how well it functioned. I used galvanized pipe, the ends are threaded and I have orange rubber covers on them that came on them and they fit very tightly in the holders. I leave the bunk up while traveling because I don't have to worry about it bouncing around causing damage. I store it in the back shelf when camping an not using it. What size poles did you buy, 1" or 3/4"?? I'm pretty sure it was 3/4". Take a bracket with you. Whatever I told my husband to buy the first time, was too big... and very expensive. I may have posted somewhere else about it. I'll look. You want the correct diameter of the pole, NOT the hole in the pole
Post by mel on Jan 18, 2017 14:53:01 GMT -8
Thanks Ten I feel bad you went out and measured since I could have done the same thing since the Airflyte came with two of the three poles, im not sure they are original. I really like seeing the retainer clip, very interesting. One of the poles in the Airflyte is slightly too long. it wont go in the second brackets out, but if I tilt it to the side and get it past that area I can get it in the 3rd bracket. I thought that was kind of strange, and it makes it pretty hard not to hit the walls since its wider than the wall in that spot. I think Im going to have to figure out how to cut the pipe down a little........ SusieQ good idea about bringing the bracket to the store. I will definitely be doing that now, dont know why I didnt think of that lol. Are you leaving the orange cap on while putting in in the bracket? There are some eye hooks at each end of my little shelf in the back of the Compact, Im thinking I will put those little tiny bungies around the hammock while traveling so it doesnt fall off.
Post by SusieQ on Jan 18, 2017 15:58:11 GMT -8
mel, I did leave the orange caps on. It fits very tight and it keeps it from accidentally scuffing the wall. And my husband just confirmed that my poles are 3/4".
Post by Ten on Jan 18, 2017 18:27:36 GMT -8
I don't mind measuring, I was pretty curious myself. Just remember that the length is going to depend on the inside width of the trailer, and will be different for makes and models. Diameter matters.
CorvettCrzy
Post by CorvettCrzy on Aug 18, 2017 6:23:07 GMT -8
I've decided to come back to this and make my canvas bunk. I've been doing some research and thought I would update this thread with some information I have accumulated in hopes of saving someone else some leg work. Here is what I've found. (Note: All of my pipe information and pictures were done at Menards and on their website, I didn't take the time to check out pipe at any other stores, I'm assuming it's pretty much the same) 3/4" Galvanized (not Conduit) vs. 3/4" Black Pipe - Pipes for bunk by Corvett crzy, on Flickr My bunk brackets measured about 1" Website specifications for 3/4" pipe show both Galvanized (for water lines) and Black (for gas lines) have an EXTERIOR diameter of 1.05" Therefore, 1" pipe would certainly not work for me. Bunk holders by Corvett crzy, on Flickr I took some pictures of the galvanized pipe with the plastic cover on the ends. This is tight but I did get it in, I'm a little concerned that it might stress my brackets and with the bouncing of a camper might break them since I have no idea what they are made of and question their hardness. It would however eliminate them from "popping out". Capped Galvanized by Corvett crzy, on Flickr However, this is what the fit looked like with the threaded end minus red cap, as you can see the diameter is smaller than the bracket, my husband tells me it's because of a tapered thread. Concerned it may be too loose. Galvanized 3/4 by Corvett crzy, on Flickr Next Consideration - Strength: Website specifies Galvanized has a wall thickness of .113" Black - nominal of .11" Weight: both at 11.3 lbs. shipping weight Black is listed at 1.03 lbs. per foot. I originally thought I would go with the Black pipe because I thought it would be stronger. I have since decided to go with the galvanized, mostly because of the finish, since they are pretty close structurally. I will either "wrap" the threads with a cloth type material (also considering a piece of adhesive velcro, soft side) or cut the threads off. Since I cannot purchase a pipe at the correct length I will probably go with cutting off both ends. Hope this helps someone else.
Post by danrhodes on Aug 18, 2017 6:36:59 GMT -8
Just a biased question, but have any who intend to use their bunk considered building a fold down wooden bunk? My camper has a rear bunk that's nearly 3/4 full size and folds up nearly out of the way when not in use. I can't imagine trying to get my kids to sleep in a cot style but they little one loves her "bunk bed"
Post by ladywendolyn on Aug 18, 2017 9:03:29 GMT -8
With the galvanized pipe, you can wrap the ends with duct tape or electrical tape and it keeps the sharp edges off and thickens them a little. I have done this successfully and it has not come off yet.
