melloyello
'62 Shasta Airflyte
Post by melloyello on Aug 26, 2013 7:09:53 GMT -8
My wife and I bought a '63 Deluxe for parts and are now considering a possible redo. I've never attempted to peel the skins back before but thought this would be the perfect time. I removed all the screws in the J channel, pulled it back and found small nails between every screw hole. Is this standard or something someone did later? Any advice on removal?
Thanks, Jerry
keri
Post by keri on Aug 26, 2013 7:48:36 GMT -8
So you mean under the j-rail, where the top skin was bent over the side skin, it is nailed down? Yes, that's standard. It's also standard to use about 6 billion nails to do it. Also, once you pull the nails for the skin overlapping the sides, there will most likely be 6 billion MORE nails holding the side skins down. But the upside is that you'll be a pro at nail-removal once you're finished!
Post by cowcharge on Aug 26, 2013 11:27:36 GMT -8
Better than trying to pull out the skinny staples that held mine on.
Post by vikx on Aug 26, 2013 21:00:53 GMT -8
Also, be sure to straighten the bent edge before moving the front/rear/roof metal. It causes the metal to split if you move it without straightening the edge...
65callie
Post by 65callie on Aug 27, 2013 5:57:15 GMT -8
So when the skin goes back on, do you re-staple/nail or ?
Post by mobiltec on Aug 27, 2013 14:53:58 GMT -8
After all new curbing is installed I staple it using 1/4 x 3/4 staples with an air gun.
Post by mobiltec on Aug 27, 2013 15:08:28 GMT -8
Post by vikx on Aug 27, 2013 21:21:30 GMT -8
So when the skin goes back on, do you re-staple/nail or ? Depends on the trailer: On mid 60s units, I staple with 1/4 x 1/2 18 ga. They hold well, but the nail gun should be set so that the staples don't go thru the aluminum. On older canned hams (50s), I use stainless 7/8 x #17 nails. Just don't want the staple dimples in that cool old aircraft aluminum. I predrill the metal with a 1/16 bit, not into the wood.
melloyello
'62 Shasta Airflyte
Post by melloyello on Aug 28, 2013 13:17:16 GMT -8
Ughhh, so any tips to make the nail removal easier and less of a pain in the...
keri
Post by keri on Aug 28, 2013 15:52:58 GMT -8
Ughhh, so any tips to make the nail removal easier and less of a pain in the... Not that I know of, but after 100 or so you'll get into a rhythm and it will start to go faster. I mostly used pliers and a screwdriver, just be careful not to tear your skin.
Post by mobiltec on Aug 28, 2013 17:57:02 GMT -8
Very small Cat's Paw you can get at Home Depot. Other than that, it's a PITA... But you get better at it as you go. About the time you have it down, you're finished...
