Post by wisconsinjoe on Mar 13, 2016 11:20:33 GMT -8
Lola53
1953 Westfield Westerner
Post by Lola53 on Mar 13, 2016 15:06:09 GMT -8
Post by wisconsinjoe on Mar 13, 2016 19:23:09 GMT -8
Mark, thanks. Looks like it's cost effective to just buy a whole new hitch. So, how does one get the old welded one off before welding a new one? Obviously I know AL, Oct nothing about welding.
Post by vikx on Mar 13, 2016 21:18:07 GMT -8
What it used to be...
Lola53
Post by Lola53 on Mar 13, 2016 21:26:03 GMT -8
Mark, thanks. Looks like it's cost effective to just buy a whole new hitch. So, how does one get the old welded one off before welding a new one? Obviously I know AL, Oct nothing about welding. Replacing the hitch is what I would do. You can start with a right angle grinder to remove the easily accessible welds. Try to leave as much of the trailer frame as possible, although small areas can be repaired when welding. If hitch does not come off after grinding the welds then a reciprocating saw (Sawsall) with metal cutting blade can be used to cut through the hitch where the unaccessible welds are located (could also use a metal cutting blade on the right angle grinder for this). Don't be afraid to use a hammer and pry bar to break any stubborn weld remnants - very theraputic for relieving frustration. :-) Better yet, find a good welder and have him remove the old hitch after you tow it to his location. Really not a very demanding task. Mark
Post by wisconsinjoe on Mar 14, 2016 5:10:50 GMT -8
Thanks again Mark. This looks like an easy fix. I really do like this style of hitch because it releases the ball so well. On my other trailers I often have to jump up and down on my bumper to get it loose.
Lola53
Post by Lola53 on Mar 14, 2016 16:40:41 GMT -8
My personal favorite is the bulldog with sliding collar. You know the lock has engaged. But I've also used the York style with excellent results. Have fun.
Mark
Post by wisconsinjoe on Apr 4, 2016 14:04:50 GMT -8
Thanks again Mark. After going round and around with E-Trailer about identifying the correct part matching with a model number that was not there, I just ordered through Amazon for $2 less and free shipping. 30 minutes later I ground off the riveted pin and assembled the new part. Done! And in the process of stripping paint off the hitch, I found the registration number of the trailer which will help me get a new title.
Post by bigbill on Apr 4, 2016 14:27:49 GMT -8
You need to put stud and bearing mount Loctite on that nut so that doesn't vibrate off and yes I see it is a lock nut but do it any way. Also with that type of hitch I like to drill a hole right behind the sliding part then place a padlock in it to prevent the hitch from coming off should the slide release, plus it discourages thieves.
Post by danrhodes on Apr 4, 2016 15:09:56 GMT -8
You need to put stud and bearing mount Loctite on that nut so that doesn't vibrate off and yes I see it is a lock nut but do it any way. Also with that type of hitch I like to drill a hole right behind the sliding part then place a padlock in it to prevent the hitch from coming off should the slide release, plus it discourages thieves. That brings up question I had... Anyone carry a spare ball just to lock to the hitch when at camp? Would require the lock to be cut to steal?
Post by Ten on Apr 4, 2016 18:19:54 GMT -8
Shastas used these hitches on most models. The lock behind the band prevents the slide from releasing from the ball, even though the band will flip up. Another view of another one:
Lola53
Post by Lola53 on Apr 4, 2016 21:53:43 GMT -8
Awesome, looks great!
Mark
Post by wisconsinjoe on Jun 26, 2016 8:54:45 GMT -8
You need to put stud and bearing mount Loctite on that nut so that doesn't vibrate off and yes I see it is a lock nut but do it any way. Also with that type of hitch I like to drill a hole right behind the sliding part then place a padlock in it to prevent the hitch from coming off should the slide release, plus it discourages thieves. Thanks Bill for the advice. Been out of the loop all spring building a Tiny House to rent out via Airbnb (based on the space efficiency found in our camper). Time to get back to this project.
Post by timthewiner on Apr 21, 2020 16:28:50 GMT -8
Hey there. This post is only a few years old and this replacement part is EXACTLY what I need for my trailer as well but now I cannot find this replacement part ANYWHERE! How is this possible? Has to still be some demand.
Post by bigbill on Apr 21, 2020 17:44:09 GMT -8
Try Rural King and Amazon both on internet
