keri
Post by keri on Aug 20, 2013 19:50:38 GMT -8
So it seems like a lot of people are using the Armstrong VCT tiles for their trailers, but what are other options? Is there a reason why tiles seem to be used more often than sheet vinyl?
I'm almost to the flooring stage and had originally just planned on a checkerboard VCT floor, but now I wondering what other options might be and maybe pros and cons of each.
Post by universalexports on Aug 21, 2013 11:25:18 GMT -8
the tiles were what was there originally, so many probably go for that. Tiles are harder and toughter than the sheet vinyl, if you get a rip in vinyl it is there forever unless you want to try and pull it all up. thats really the only thoughts I have on it...
Post by cowcharge on Aug 21, 2013 17:50:00 GMT -8
You might consider self-stick vinyl tiles, they are very easy to replace if one gets scratched up.
Post by Hamlet on Aug 21, 2013 19:04:33 GMT -8
Today's VCT tiles are much thicker and heavier and stiffer than the ones that were originally in the trailers. I suspect that if Shasta were doing it today, they'd probably use vinyl sticky tiles and not VCT. Others have used real linoleum (Marmoleum, Marmorette, or Harmonium), which was in the earliest Shastas (1960 and before). It is more expensive than VCT, but is a natural, biodegradable product made mostly of linseed oil and sawdust. If you use VCT, you will need to apply several coats of finish to bring it to a gloss, and redo it once every few years. Linoleum comes pre-finished in a softly glowing finish, so if you like the really shiny look, go with something else. If you want to do something artsy with the floor (other than just a checkerboard look), you'll need to use linoleum, or something equally flexible. The one thing to be said for sheet flooring (despite the difficulty repairing it if it gets a divot) is that there are not a lot of seams. This can be a boon if you do a lot of boondocking or camp in sandy, or very dirty areas.
keri
Post by keri on Aug 21, 2013 19:29:15 GMT -8
Are the VCT tiles easy to cut? That's probably what I'll end up going with. I like the checkerboard! My Bellwood originally had some kind of sheet vinyl. It's black on the back and some kind of weird/ugly swirly pattern on the top--probably full of asbestos but we will all die of something right? Lol.
Post by mobiltec on Sept 5, 2013 9:58:04 GMT -8
Are the VCT tiles easy to cut? That's probably what I'll end up going with. I like the checkerboard! My Bellwood originally had some kind of sheet vinyl. It's black on the back and some kind of weird/ugly swirly pattern on the top--probably full of asbestos but we will all die of something right? Lol. Keri I'm surprised at your question... I have at least 3 or 4 videos on VCT installation. It cuts with a razor knife very easily. There are two ways to cut it. One is to just scribe it with the razor knife and then break it. The other is to heat it up with a $19 heat gun and then it cuts like a hot knife through butter. Each method has it's place in the installation. Go take a look at the website. It's easy really. It usually takes me around 6 hours start to finish for an average sized trailer once the floor is ready for glue. Two hours of that is just waiting for the glue to dry before installing the tiles. Armstrong VCT is what is used in Walmarts... So it's really tough. I put 5 to 6 coats of polish on it when finished and it looks great. You can do it with just 3 but you know how I am...
keri
Post by keri on Sept 5, 2013 10:50:07 GMT -8
Haha. You called me out Larry! Yes, since that question I've gone back and watched all of your videos and Redneck Responders. So I know how to cut it now. It's easy!! And I don't think I'll even have any hard cuts so that's good.
My Home Depot store had a box of the VCT color chips so I was able to get some ideas of what colors I'm going to do. It's handy when you can actually see the colors in person.
Post by mobiltec on Sept 5, 2013 16:25:20 GMT -8
OK Keri... LOL... It takes about two boxes to do an entire trailer under the bed and cabinets and everything. Keep in mind that if you do all one color, you will see the lines where they all connect very quickly because no matter how much polish you put on the floor, the seams will collect a little dirt. I think that is the main reason for alternating colors in a checkerboard pattern. You can see an example of that in the big motor home that I tiled last month. That one is in Trailer Tidbits. It still looks great but I don't like being able to see the lines.
smccusk
63 SC Restoration in progress
1963 Shasta SC
Post by smccusk on Sept 5, 2013 18:25:05 GMT -8
When I did my floor two boxes of VCT where perfect...I did the floor and bathroom with left overs incase you bonked.
keri
Post by keri on Sept 5, 2013 18:48:44 GMT -8
I'm definitely going to do the checkerboard--it just looks more fun! Now the chore is to decide which colors!
The lady at Home Depot said it would take about 2 weeks to get the tiles in--just for anyone wondering. And they had plenty of the glue in stock. So that was good.
I'm looking forward to doing the floor!!!
Post by mobiltec on Sept 5, 2013 19:06:28 GMT -8
To me the floor is the most fun part of the project. It also means you are getting close to the end.
Post by Hamlet on Sept 5, 2013 20:22:57 GMT -8
Unless ou are doing a frame-off, then the flooring goes in before the walls go on. It helped us to have it done as it made it look as though there was really going to be a trailer on top of it someday!
Post by mobiltec on Sept 6, 2013 6:59:24 GMT -8
Unless ou are doing a frame-off, then the flooring goes in before the walls go on. It helped us to have it done as it made it look as though there was really going to be a trailer on top of it someday! Yep. Then the floor is done pretty early in the game. Then you want to re-finish all your cabinets before you put them back in. Walls too. Of course the ceiling must be done after it is installed but all you have to do is cover the floor really well to protect it.
