Post by vikx on Mar 13, 2016 12:03:10 GMT -8
mel: please re-post your photos and some further away so we can see the whole window. The photos above disappeared...
Post by mel on Mar 13, 2016 16:35:12 GMT -8
ok my photos are back, and I will post some photos of the whole window tomorrow
Post by mel on Mar 14, 2016 16:15:17 GMT -8
Post by vikx on Mar 14, 2016 19:44:43 GMT -8
Only the last two photos are showing for me.
That window appears to be a replacement. I would guess it the inner metal rimmed section is seated in glass seal or sticky putty. Have you tried to dismantle the window? Clips on the outside holding the inner piece in place?
Post by SusieQ on Mar 14, 2016 23:03:14 GMT -8
Do you think the glass was replaced and they put it back together without the glazing strips and used that gasket looking piece instead?
Post by mel on Mar 15, 2016 4:15:44 GMT -8
Post by mel on Mar 15, 2016 4:16:45 GMT -8
I have tried taking it apart yet.
Post by vikx on Mar 15, 2016 20:12:57 GMT -8
It looks like an entirely different window than Shasta normally used... Maybe the inside was set into the original frame? I think one option may be to remove the inset, seal with good caulk and go with it. Another option is to take it to the glass shop.
Honestly, I think you can do better than a glass shop. Take it apart and clean it up really well. See if the inset will come out...
