Post by mel on Mar 2, 2016 14:08:20 GMT -8
Is there a certain seal I need for my compact back window?
Post by nccamper on Mar 2, 2016 19:54:07 GMT -8
Post by SusieQ on Mar 3, 2016 3:01:20 GMT -8
The back windows are famous for leaking. The seal inside the window will most likely need to be replaced. It's not difficult. The most difficult part is getting the glazing strips out without damaging them but if you do that correctly, you won't have any problems. Make sure you clean off all the residual dried black butyl.
Post by mel on Mar 3, 2016 5:01:18 GMT -8
So there is not actually a rubber seal I need? just the black glazing tape?
Post by nccamper on Mar 3, 2016 6:29:14 GMT -8
My 62 Compact had just glazing tape. No rubber gasket. Odd, but it worked.
65callie
Post by 65callie on Mar 3, 2016 6:51:34 GMT -8
Our '62 compact didn't have the angled side pieces. Instead it had a flexible gray strip. I almost had the glass out when it broke This is what I bought to replace the old flexible strip that holds the glass in (in addition to using the black glazing). It fits just like the original. www.vintagetrailersupply.com/Hehr_Clear_View_Window_Strip_p/vts-196.htm
Post by mel on Mar 12, 2016 20:57:06 GMT -8
Our '62 compact didn't have the angled side pieces. Instead it had a flexible gray strip. I almost had the glass out when it broke This is what I bought to replace the old flexible strip that holds the glass in (in addition to using the black glazing). It fits just like the original. www.vintagetrailersupply.com/Hehr_Clear_View_Window_Strip_p/vts-196.htmCould you post a close up of your back window? Mine looks a little different than nccampers but doesn't seem like it has a gasket like yours.
Post by SusieQ on Mar 12, 2016 21:59:06 GMT -8
I'm a little late with this but here is my window disassembled and the put back together. Yeah, it has a flying pig on it, .
Post by mel on Mar 13, 2016 4:57:16 GMT -8
Post by SusieQ on Mar 13, 2016 6:37:05 GMT -8
Mel, are the top two pics of the outside of the window? I'd take that gasket off first to see what's behind it. Almost looks like a channel for the gasket. Then you might be able to tell what is holding it in. Somebody... vikx? has seen a window like this. There's no way you have the only one, lol.
Post by mel on Mar 13, 2016 6:40:16 GMT -8
Yes, all the photos I posted are the outside of the window
Post by mobiltec on Mar 13, 2016 7:25:30 GMT -8
Haven't seen one like that till now.
Post by mel on Mar 13, 2016 7:40:41 GMT -8
Hamlet what does your back window look like?
Post by SusieQ on Mar 13, 2016 8:09:34 GMT -8
If those are all of the outside, post the pics of the inside.
Post by mel on Mar 13, 2016 10:13:03 GMT -8
