spoma
Post by spoma on Feb 23, 2016 8:19:18 GMT -8
I have a 1969 Shasta Starflyte that I am in the early stages of restoring. I am trying to get a lot of the planning out of the way now, during the winter months, so that I am ready to start the project as it warms up.
My wife has decided that we will paint the interior of the trailer white. I like the wood finish look, but I have been overruled.
I have read many threads on the different woods used and it seems most go towards the 1/8" birch look. I am wondering if the selection is as critical if the wood is going to be painted. Does anyone have any experience with painting the interior of the trailer and which wood species they choose for this? It might just be a personal decision at this point and if it is that's fine, but I just want to make sure there isn't a structural advantage to one over another.
thanks.
Post by Hamlet on Feb 23, 2016 9:06:55 GMT -8
Folks who paint often use luan. It acts like birch, but has little grain, so isn't real pretty and takes paint well. You may want to consider the type of paint. An eggshell or even a semi gloss will reflect light and make the trailer seem larger and brighter. We accomplish something similar when we use a sheen on birch.
spoma
Post by spoma on Feb 23, 2016 9:31:27 GMT -8
Thanks Hamlet.
My wife wants the gloss look in the trailer. I think glossy will be to much so it will probably end up a semi gloss, but i plan test the paints on the wood that is chosen.
Does luan offer enough strength? i guess it would since it would still be the same thickness. thanks for the info.
spoma
Post by spoma on Feb 29, 2016 18:53:07 GMT -8
I was at home depot today looking at the different woods and was looking at the luan. They don't carry 1/8" luan at my home depot but they had 'almost' 1/4" and I was looking at that. Luan scares me. It seems very week and brittle. Also doesn't look like the glue is very good and I wonder how it will hold up to water.
Is luan really strong enough to use?
Thanks for all the help.
Post by danrhodes on Feb 29, 2016 19:03:25 GMT -8
I was at home depot today looking at the different woods and was looking at the luan. They don't carry 1/8" luan at my home depot but they had 'almost' 1/4" and I was looking at that. Luan scares me. It seems very week and brittle. Also doesn't look like the glue is very good and I wonder how it will hold up to water. Is luan really strong enough to use? Thanks for all the help. If it's Chinese, you might find the glue actually isn't very strong. It's worth the $20 investment to buy a sheet, rip some pieces and try bending, breaking and peeling it. I bought some 3/4" plywood at home depot that you could literally rip apart with your fingertips.
spoma
Post by spoma on Feb 29, 2016 19:27:07 GMT -8
I'm going to call the local lumber center by me and see what they have in 1/8" for different species and pricing. i think i might go with something other than luan. probably cost a little more money but going want to make sure it has strength.
the stuff my home depot had for luan was birch luan Grade C, made in china.
chriss
Post by chriss on Mar 5, 2016 5:09:20 GMT -8
I would skip the box store material, unless it's in a hidden area. The utility plywood I bought at Lowes had many irregularities in the surface that showed up when the light hits it just right. Ended up getting some birch at our local millwork supplier for $20. Painted up very nice. There's something else I used from lowes, it's an underlayment plywood. Says it's moisture resistant and has kind of a red/pink color on one side. I used it behind the galley since it won't be seen. For paint, I used satin. May go semigloss next time I paint. I would never use flat.
spoma
Post by spoma on Mar 6, 2016 18:43:04 GMT -8
I found this stuff at home depot and was pretty excited about it. www.homedepot.com/p/Utility-Panel-Common-1-8-In-x-4-Ft-x-8-Ft-Actual-0-106-in-x-48-in-x-96-in-833096/100535208It has some irregularities to it but they won't show up when painted. I picked up a bunch of sheets the other day and was planning to start and rebuild one wall this week. But, today I got a little deeper and took apart the first wall that needs to be rebuilt. I noticed that the original material that is on the walls in the trailer is much thicker than 1/8". It is much closer to 1/4" and my guess is 1/4" material which tends to be a little thinner in actuality. The stuff I picked up is actually slightly thinner than 1/8" in that it is .106". I am not having concern that this might be to thin and won't offer the structural integrity that this framework requires. Anyone have any experience with this stuff? Think I am better off going with 1/4" material even though it will be heavier.
Post by vikx on Mar 6, 2016 20:44:00 GMT -8
I would go with the 1/4- for the walls. 1/8 is usually used for ceilings on canned hams because it will follow the curve.
carvelloafer
1959 Lil Loafer
Post by carvelloafer on Mar 7, 2016 4:52:31 GMT -8
I would say you should consider if you want to see wood grain texture through the paint or have a smooth finish. I'm guessing you want smooth if you are thinking of semi gloss.
Birch and maple will paint the smoothest. Oak and ash will allow you to paint thin and see the texture. I'm not familiar with luan but I believe it is like a cheap mahogany grain, which if it is my guess is it might not paint out as smooth as birch.
Pine or fir plywood will show a lot of texture.
spoma
Post by spoma on Mar 7, 2016 16:14:49 GMT -8
we do want a smooth look. I am figuring with a good primer coat (maybe two) and a semi gloss paint on top of that, I should be able to get a pretty good look. I will apply the paint in many light coats and sand lightly between each coat.
