Post by SusieQ on Jan 18, 2016 10:25:31 GMT -8
I did a quick search for the vent diagram and came up with nothing but I'll look later when I have more time. Here is the famous ugly Shasta vent on my '65.
Post by nccamper on Jan 18, 2016 10:28:33 GMT -8
That vent sure is...well...ugly. At least it's really big.
Post by SusieQ on Jan 18, 2016 10:37:07 GMT -8
That vent sure is...well...ugly. At least it's really big. And the propane fridge was replaced with an electric one that doesn't really need that much vent. I do have an extra 2-way that may or may not work that I could possibly replace it.
Post by katiebronleewe on Jan 18, 2016 10:46:11 GMT -8
Goodness that's a big vent! We are planning to use the floor to ceiling closet for a ports potty, if possible. So that only leaves kitchen cabinets for the fridge. After working this weekend it seems we'll be removing all skins and reframing and everything so I guess we could cut spots for new vents for the fridge. Won't look as nice from the outside, but we are placing pretty high value on being able to boondock, so I guess we really do need the propane.
Post by SusieQ on Jan 18, 2016 11:05:02 GMT -8
Goodness that's a big vent! We are planning to use the floor to ceiling closet for a ports potty, if possible. So that only leaves kitchen cabinets for the fridge. After working this weekend it seems we'll be removing all skins and reframing and everything so I guess we could cut spots for new vents for the fridge. Won't look as nice from the outside, but we are placing pretty high value on being able to boondock, so I guess we really do need the propane. It's only vented at the top and the bottom so I'm not sure that one for that size cut out is necessary. But it is necessary to vent it in both places, top and bottom.
Post by Ten on Jan 18, 2016 11:51:07 GMT -8
There is some discussion here: vintagetrailertalk.freeforums.net/thread/5843/fridge-ventabout just this subject, along with some photos. The principles will always be the same. So will all rules applying to proper and safe installation. Be sure to pick out the unit before you do any cutting. Follow the manufacturer specs for sizes of opening for venting. THEN cut holes through the walls. It is much easier than uncutting them. EDIT: By the way, this vent is the same type as the bottom vent in my 16SC. This is the one on my Airflyte: The lower vents are usually larger, and are accessible, so that servicing the business end of the fridge is possible.
Post by mobiltec on Jan 18, 2016 17:24:07 GMT -8
You need a vent at the bottom of a propane fridge for two reasons. One, so the cool air has a place to come in at the bottom where there is no heat. Two so that if a propane leak develops the propane has a place to run outside of the trailer. You need a vent at the top or on the side at the top for the hot air to run out. And it won't run out if you don't have a place at the bottom for the air to come in at.
Post by vikx on Jan 18, 2016 21:58:42 GMT -8
Good info above. You don't need that "ugleee" vent, just a tasteful one at the bottom and one at the top. Baffles may be necessary if you vent thru the side, but installation instructions are pretty clear. I can share photos with you via email.
