Post by universalexports on Aug 11, 2013 17:10:17 GMT -8
I am about to start making my drawers, has anyone built their own?
i was just going to use 1/2 inch x 4 inch lumber for the sides, and 1/4 flooring for the bottoms and use about 20 screws around the bottom to attach it.
Ive been looking and most use wood with a 1/4 inch groove near the bottom to slide the 1/4 floor into is this the best way, I have a router, can I use that to make the groves? ideas?
what do you use to keep the cabinets shut during travel?
gettinolder
Post by gettinolder on Aug 11, 2013 18:33:48 GMT -8
Dad always used the table saw for the kerf at the bottom of the drawers. Kept it a lot straighter than using router.
I have seen drawers held shut with cabinet door catches. A roller catch between the front of the drawer box and the cabinet frame would be neat. Might have to go a bit thicker with drawer box to give room to mount the roller catch.
Post by universalexports on Aug 11, 2013 18:35:05 GMT -8
I have a table saw and thought about that, but I would have to make two passes, the blade is only 1/8 inch thick.
gettinolder
Post by gettinolder on Aug 11, 2013 18:53:11 GMT -8
2-3 passes or get a Dado blade. Until you get to wider Dado Joints, multiple passes is LOTS cheaper.
Post by bigbill on Aug 11, 2013 20:02:08 GMT -8
Drawers are sometimes held shut by making a notch in the bottom sliding surface just as wide as the front edge or you can add a small board about 1/4" thick at the front to catch in the notch on the bottom of the drawer then you just lift up and pull to open.
61 Shasta
Post by 61 Shasta on Aug 12, 2013 12:05:56 GMT -8
Universal, I make my own drawers. I start out by measuring the opening to assure that the final product will fit the opening. If you are using purchased store glides be sure to allow 1/2 inch on each side for the glide. (Drawer will be 1 inch narrower than the opening). I use 1/2 inch plywood for the drawer sides, front and back and any scrap 1/8" to 1/4" material I might have for the bottom. I find that 1/4 inch underlayment works great. I use dado joints on all four corners and a dado on the bottom so the bottom fits flush with the sides. This allows for a better joint that will glue and nail up and stay in place. Once this "rectangular box" is made up, glued and nailed, I prefit it and if everthing is good, I attach my finished front to it and you are in business. For the joints, I use my pneumatic stapler with 1/4 inch crown staples (1 inch) and a good glue. I use tightbond. Here are a few pictures to put what I have said in picture format. This first photo is a top view with the front of the drawer on the left. Overall view of the bottom Showing how the bottom is flushed out: This view of the front dado is typical of all four corners
Good luck and hpe this helps
Post by universalexports on Aug 12, 2013 14:53:59 GMT -8
thanks, I dont have a pneumatic stapler, but I like how you done it, I usually pre-drill a hole and use small screws.
