dragonwagons
Polish
Post by dragonwagons on Aug 10, 2018 14:21:23 GMT -8
Not a clue. I also have a hydro flame mine needs a new thermostat, I think ,it just runs full hot. The thermostat is just a metal tube with a larger piece on the end.
Anyway good luck finding the valve and if you fine a thermostat (temperature probe) let me know I’m interested to see if it fixes mine. For now I just turn it on and off.
yob
Post by yob on Sept 26, 2020 15:58:40 GMT -8
this is old thread.i lit my furnace!I have the same heater.your post was super spot on.thank you
normane
Post by normane on Nov 5, 2021 14:38:26 GMT -8
We have a 1968 Kit Companion 17 footer. It has a Hydro Flame propane furnace that was working great, until the flow control handle fell off (somehow managed to unscrew itself over time). The furnace looks identical the photo's here (so likely an ARS-10L as well.)
But of course, I had to remove the flow control assembly so could screw the handle back on, but that resulted in several springs and pieces coming apart when I pulled out the flow control assembly.
Try as I might, I can't seem to find the correct positioning of the springs and a small plate that fits with the springs.
I realize its a long shot, but does anyone have a photo or assembly diagram of how to put the flow control back together?
