Post by trihartsfield on Jul 7, 2015 18:12:54 GMT -8
VIN 24191
Thanks
theresa
Post by theresa on Jul 7, 2015 18:53:11 GMT -8
Ross should be able to help you with this. Do you happen to know the model?
Post by Ross on Jul 8, 2015 3:12:36 GMT -8
I would be happy to help you, but your vin# is missing the prefix letter....?24191 and as Theresa mentioned, do you know what model you have? If not, can you measure the body (front to back) and the overall length (tongue to bumper)? These measurements will help with determining what you may have.
Thanks.
Post by trihartsfield on Jul 8, 2015 10:53:42 GMT -8
I have sanded the VIN plate to shiny metal. No letter preceding the VIN #.
The size is 16 feet from tongue to bumper. Came with the wings
I will try to upload a picture of the VIN plate.
Thanks
Post by Ross on Jul 8, 2015 10:59:37 GMT -8
If there is a small green metal plate beside the entry door, it will state where your Shasta was manufactured. This will help.
Post by trihartsfield on Jul 8, 2015 10:59:49 GMT -8
Post by Ross on Jul 8, 2015 11:32:58 GMT -8
Post by trihartsfield on Jul 8, 2015 11:56:25 GMT -8
Post by Ten on Jul 8, 2015 16:36:12 GMT -8
Believe the "Moon" photo to be a mid-60's 1500. The "spear stripe" was used from early '65 till sometime in early '68.
Post by Ross on Jul 9, 2015 3:54:00 GMT -8
If your Shasta was born in California, there should be another vin# stamped plate on the tongue.
Post by trihartsfield on Jul 9, 2015 10:05:56 GMT -8
If your Shasta was born in California, there should be another vin# stamped plate on the tongue. No other VIN plate in the tongue.
Post by trihartsfield on Jul 9, 2015 10:08:17 GMT -8
 Plate just left of the door at eye level.
Post by trihartsfield on Jul 10, 2015 17:55:44 GMT -8
 OK I found a plate on the back of the trailer. Does this mean it is a 1966?
Post by Ross on Jul 11, 2015 4:11:18 GMT -8
Based on the info on the DOH tag, your Shasta's vin# reads: ?S24191-??3928
Usually, the ?'s would have letters. In North Ridge, California, the first prefix letters were either D, DS, ES, FS, GS, HS or HT. The second set of ??'s would have been either FA or PA.
Now, all this being said, I believe your Shasta's vin# to read: GS24191 . If a title is or were available, this is how it would or have probably read. In 1965, based on the vin#s that I have collected from North Ridge, the last set of letters & numbers were really being hard to locate.
Would love to see some pictures of your Shasta and maybe we can help determine the model that you have.
Hope this info helps.
Post by trihartsfield on Jul 13, 2015 7:54:54 GMT -8
 Had the orange stripe before I replaced the lower panel. It has wings just currently off.
