Post by mel on Jun 29, 2015 5:31:56 GMT -8
I keep seeing people write "ice pick test" what does it mean? I have searched it and can't find any info about what it actually is and how to do it
Post by vintagebruce on Jun 29, 2015 5:55:40 GMT -8
When you go to inspect a camper, starting with getting under the camper and thoroughly inspecting the bottom sills which are wooden, if you have an ice pick or something similarly sharp and pointed, wherever you see obvious spots of rot or possible deterioration, or just "suspect" areas that might be discolored try and push the tip of the ice pick into the spot and if it sinks in easily fan out in close proximity to see how much wood in the area is also soft enough to allow the pick to penetrate A few pick holes will not damage the camper, but they might be enough to allow you to decide whether you want the camper and give you leverage to negotiate a reduced price. Pick in all areas of suspected moisture intrusion throughout the camper. If the seller refuses to allow a pick here and there they are probably wanting to hide known problems, especially if the interior is painted. Sometimes owners glamp a camper not because of preference but need to hide areas of deterioration/moisture damage. I might use the smallest jeweler's Phillips head screw driver I have instead of an ice pick. Much easier to palm when you go under the camper.
Post by mel on Jun 29, 2015 8:30:34 GMT -8
When you go to inspect a camper, starting with getting under the camper and thoroughly inspecting the bottom sills which are wooden, if you have an ice pick or something similarly sharp and pointed, wherever you see obvious spots of rot or possible deterioration, or just "suspect" areas that might be discolored try and push the tip of the ice pick into the spot and if it sinks in easily fan out in close proximity to see how much wood in the area is also soft enough to allow the pick to penetrate A few pick holes will not damage the camper, but they might be enough to allow you to decide whether you want the camper and give you leverage to negotiate a reduced price. Pick in all areas of suspected moisture intrusion throughout the camper. If the seller refuses to allow a pick here and there they are probably wanting to hide known problems, especially if the interior is painted. Sometimes owners glamp a camper not because of preference but need to hide areas of deterioration/moisture damage. I might use the smallest jeweler's Phillips head screw driver I have instead of an ice pick. Much easier to palm when you go under the camper. Thank you I know mine has some rot, and I know I'll see it all as soon as I take it apart, but I want to do it just to get a better idea now, we won't be take the skin off until next year.
