Hugh
Post by Hugh on Jul 23, 2013 9:47:01 GMT -8
I'm sure our new tow vehicle (Xterra) will have a problem opening the rear hatch, at least when the window rock guard is up. I'm toying with the idea of extending the tongue of Shasta. Shasta is a 1955 Shasta 1500. This will accomplish two things 1) allow opening the back of Terra without unhooking the trailer and 2) increase stability while towing. We've had little trouble towing (2003 Toyota Tacoma Extended Cab) but it sways slightly at times. Has anyone extended the tongue of their small trailer? How much? Did it seems to improve stability? At the Mitchell, OR rally there was a trailer with a folding tongue. This looks like a great idea and they still produce the coupler. Has anyone used these? www.fultonperformance.com/content/products.aspx?lvl=2&parentid=7000&catID=7060&part=0It looks like they make bolt on and weld on couplers. If I extend our tongue I'll likely incorporate one of these. Then I know it'll still fit the storage unit. It may be hard to add a anti-sway damper to a straight tongue though. Any thoughts? Along those lines, is anyone using an anti-sway damper? Thanks for your help.
gonekayaking
1956 Shasta 1500
Post by gonekayaking on Jul 23, 2013 10:07:30 GMT -8
Hugh
Post by Hugh on Jul 23, 2013 10:17:21 GMT -8
GoneKayaking:
Extending the receiver, extending the hitch rather than the tongue, would solve the clearance issue with the tow vehicle. However, it has the opposite effect on stability. Moving the hitch point further way from the tow vehicles axle will reduce stability. That's why 5th wheel trailers put the ball right over the rear axle of the pickup. I think extending the receiver would just add problems but does anyone have experience with these?
Thanks.
Post by kto17 on Jul 23, 2013 11:07:41 GMT -8
We ran a 12" receiver hitch extension with our Astrodome behind a full size bronco with no sway control and no problems.
Adding an extension is going to put it a similar distance from the axle than a comparable pickup of that size would have the receiver hitch.
Use a friction control to control sway.
tiajannet
Post by tiajannet on Jul 23, 2013 11:40:13 GMT -8
I tow with a 02 Ranger V6, the bar with the ball on it that goes into the receiver was custom made longer than normal so my trash trailer wouldn't jack knife into my truck. I never had sway problems with it on that trailer so I use it with My Little Shasta, compact, and I don't seem to have any sway problems. But then again I don't have huge amounts of experience either. I can put my tailgate down and not make contact with the crank. The longer bar makes maneuvering easier, too. It was suggested as a just because to put on a sway bar, some states require them, haven't done that yet. I'm in FL.
Post by bigbill on Jul 23, 2013 13:20:40 GMT -8
A receiver extension will have little or no effect on towing BUT it does increase the load on the receiver so you have to take the length the extension into consideration or you could wind up with receiver failure causing a serious accident. to give you an example if you add a foot extension to a wrench handle it is much easier to break a bolt, the same applies to a hitch. many people use extensions very safely but you have to be certain that your receiver is rated strong enough to handle it. I am trying to remember the reduction and I am not certain but i think you subtract 33% off your receiver rating for each foot of extension In other word a 500 lb tongue weight receiver would be dropped to 330 lb tongue weight receiver. Increasing the length of the trailer tongue will have positive effects on towing plus add clearance, the greatest improvement will be in backing the trailer. The longer a trailer is from hitch to axle the easier it is to back. If they install a sway bar on a straight tongue normally they make a stand off bracket for the tongue which sits the sway bar at the same angle as if it was on an angled tongue.
Post by bigbill on Jul 23, 2013 13:36:43 GMT -8
I plan on extending the tongue on my 1500 to allow me to carry two recumbent trikes in between the trailer and the tow vehicle. It will be fastened to the trailer frame back under the trailer and extend out with a trailer ball mounted to hook into the original coupler on the trailer then on to a new coupler that will hook to my hitch. It will be bolted to the trailer frame with at least 4 grade 5 bolts 1/2" in diameter at the rear then the existing coupler at the front by a 2" ball. This will not only add extension but will make the trailer frame stronger.
gonekayaking
1956 Shasta 1500
Post by gonekayaking on Jul 23, 2013 14:18:12 GMT -8
Bill, What you are saying about extending the receiver makes a lot of sense. Do you have any pictures of the set up with the sway bar added to the extended tongue?
Post by bigbill on Jul 23, 2013 17:29:52 GMT -8
No almost all of my pictures got lost years ago during a remodel we think they got trashed by accident. If you visit a website that deals with big boat trailers you might find a picture, but even most of them have angled tongues now days. I would think any shop that installs them could tell how they do it. I personally don't like them they are mostly used to cover up mistakes in set up, just my opinion.
Post by vikx on Jul 23, 2013 21:08:29 GMT -8
We often use a 12" extension with no towing problems. It also makes backing so much easier! Here is a photo of the extension: And another: The owner of the above added a sway bar that made a huge difference when Semis would pass: Side View:
Post by bigbill on Jul 24, 2013 3:27:33 GMT -8
The above pictures show a receiver extension like I was talking about earlier. These will tow well but as I stated in an earlier post they multiply the receiver stress due to leverage. When using an extension such as this you must reduce the rated tongue weight capacity of your receiver by approximately 33% per foot of extension. It doesn't affect the total pulling rate, just the tongue weight rating. You will see a lot of truck campers using these extensions to pull their boats. I have seen these up to 3 feet long but they have to have extra support both up and down and side ways, they usually have a support hooked to the bottom of the camper or a brace system that hooks to rear of truck to help carry the load. A one foot extension in a hitch rated at 500 pound dead weight would most likely pull the average single axle trailer with no problems but before using an extension check the rating of or hitch. Different hitches will range from 200 to 1000 pounds of tongue weight. These extensions also change the load on the rear suspension of your tow vehicle. If in doubt check with the mfg of your hitch. Stay safe and enjoy life.
Post by vikx on Jul 24, 2013 23:06:52 GMT -8
Thanks Big Bill. All of our vehicles are rated at 5000lbs plus with appropriate tongue weight for the hitch. I sometimes forget that there are smaller vehicles used for towing.
Hugh
Post by Hugh on Jul 26, 2013 8:48:54 GMT -8
There's nothing like experience. It seems many are using receiver extensions with great success. Moving the ball further from the rear axle will decrease stability. Any trailer sway will be amplified through this increased offset. However, it seems the affect isn't large as many have found through experience.
The distance between the ball and axle on an Xterra will be less than on our Tacoma which should increase stability. The wheel base of the Xterra is less than the Tacoma though, decreasing stability slightly. But the Xterra weighs more than the Tacoma (3515lb to 4408lb) which should increase stability. [The weights surprised me, I didn't think there was that much difference till I looked it up.] My guess is the Xterra will be more stable than the Tacoma, but only testing will tell the truth.
A receiver extension will put more weight on the back of the vehicle. It will make the Xterra "squat" more. This depends on the suspension so it's hard to determine without trying it. We could put on air springs to fix this though. Probably still easier than extending the trailer tongue.
As mentioned, a receiver extension will lower the towing capacity. E-Trailer suggests a reduction of 50% in both capacity and tongue weight. They say this for all their extensions though, no mater how long. Bigbill suggests 33% reduction in tongue weight per foot of extension. That makes more sense as the reduction will depend on length. For our trailer, 2400 lb and 240 lb tongue, we'd be OK up to 18" or so of extension. Both our Tacoma and the Xterra have ratings of 5000 lb and 500 lb.
So, we'll try a receiver extension. The Xterra should show up the middle of August. We'll have to align Shasta and Terra to see how long an extension we'll need. But a receiver extension would be sooo much easier than extending the tongue that it's worth a try.
Thank you all for the input. I'll let you know how it works out and what we finally end up with.
Post by vikx on Jul 29, 2013 22:38:42 GMT -8
JMO: not longer than 12" with an extension...
Post by bigbill on Jul 30, 2013 5:34:09 GMT -8
Hugh you most likely will get away with it but you are pushing the ragged edge, I like a larger margin than that. Good luck and I hope you don't have any problems. I agree with vikx 12" max without additional support both horizontal and vertical.
