Post by bigbill on Aug 11, 2013 0:28:58 GMT -8
One we had years ago the sides fastened on with dot snaps, worked well.
redwings
Post by redwings on Aug 11, 2013 8:32:22 GMT -8
Interesting! I couldn't see the Facebook photos but could get to Tim Heintz's setup. The wood pole supports look like a definite option. I've never thought of the long one-piece wood support poles as an option but they look terrific! And hanging walls like you said would work well.
For the sides you could do the same wood pole setup but sling them through sewn in fabric tabs.
Ooooh the ideas!
db1955
Post by db1955 on Oct 4, 2013 16:51:22 GMT -8
I have an original canvas walled room awning for my 1964 Airstream Safari. The sides attach to the trailer with rope and slide channel like the top of many rope and pole awnings. The sides and front zip together at the corners and they all clip onto the top with D rings at the top and spring clips on the sides and front. It has a door and screened windows with roll down canvas coverings. It also has a snap on skirt attached to the trailer. Here is a link to many photos I have posted on "FLICKR" www.flickr.com/photos/dennis-blakesleyI hope this is helpful for you all who like the idea. Mine does not require ropes at the poles to be supported. I have never seen another like it. We think it is pretty cool.
gonekayaking
1956 Shasta 1500
Post by gonekayaking on Oct 14, 2013 7:35:55 GMT -8
Db1955...thank you for all the excellent pics of your set up. It would work great on a smooth sided trailer without brakes. An awning rail on the sides of a shasta might be a little distracting though I have seen that on a Shasta Airflyte here in CA that is owned by the fellow who publishes Vintage Camper Trailers . I think some combination of the screw in snaps on the sides with a flap that folds over to create a "seal" of sorts along with the other pieces you have here would work just about right. I know that Marti has been working on these for a couple of years as well.
redwings
Post by redwings on Nov 11, 2013 20:02:05 GMT -8
I have come up with another idea on how to attach side walls and will be trying it out next week. I plan on putting grommets in the wall sections and grommets in a separate double layer flap that hangs down just inside the scallops. Then I am figuring on getting small carabiners to easily attach and detach the walls. I'll let you know how it turns out (with pics, of course....)
