Post by vikx on Feb 27, 2015 21:06:41 GMT -8
You'll never gain 1 3/8"... I'd say an inch at most.
If you are determined:
1. Remove door and frame. 2. Loosen the skins at the side of the opening. 3. Using a Multimaster, carefully trim just enough to squeeze the fridge in. Be sure the slots are cut where there is a free space behind. (in other words, watch for cabinet knobs, heaters, etc. The slots could be cut high or low, either or... You may have to bend the skin edges a bit. 4. you can probably use the trimmed pieces to fill in. I'm thinking if the fit is good, they could be tacked in place rather than glued. Fridges do need to come back out at times. (Normally, I would Gorilla Glue the pieces.) Also, if the trimmed area will not interfere with the door mount, you may not have to fill in at all.
I think it will work!
chametzoo
1960 Mobile Scout
Post by chametzoo on Feb 28, 2015 11:28:10 GMT -8
You'll never gain 1 3/8"... I'd say an inch at most. If you are determined: 1. Remove door and frame. 2. Loosen the skins at the side of the opening. 3. Using a Multimaster, carefully trim just enough to squeeze the fridge in. Be sure the slots are cut where there is a free space behind. (in other words, watch for cabinet knobs, heaters, etc. The slots could be cut high or low, either or... You may have to bend the skin edges a bit. 4. you can probably use the trimmed pieces to fill in. I'm thinking if the fit is good, they could be tacked in place rather than glued. Fridges do need to come back out at times. (Normally, I would Gorilla Glue the pieces.) Also, if the trimmed area will not interfere with the door mount, you may not have to fill in at all. I think it will work! Thanks for your encouragement and detailed instruction! We'll see...
chametzoo
1960 Mobile Scout
Post by chametzoo on Feb 28, 2015 12:38:51 GMT -8
Also… a very good source on the operation (and pitfalls) of gas absorption refrigerators. www.arprv.com/
