WarPony
Post by WarPony on Jul 13, 2013 12:21:57 GMT -8
My Compact has the piano hinge on the door BUT it also has 3 "L" hinges for the screen door to attach. The bottom one is broken through the screw holes. Is there a company that offers new hinges as a whole unit or can you buy just the "L" pieces and replace as needed?
Jeff
Post by vikx on Jul 13, 2013 21:55:09 GMT -8
I haven't found replacements but you could have one made. Installing it would involve pulling that LOOOOOOONG pin. Luckily, it's the bottom hinge.
WarPony
Post by WarPony on Jul 14, 2013 3:46:49 GMT -8
The hinge pin loops would be the hard part.
Jeff
wingedwonder
Save the Domes!!
Post by wingedwonder on Jul 14, 2013 6:22:56 GMT -8
PO cut those L brackets off on my project Airflyte. Now I have a gap. I tried buying the entire hinge from another member on the other board but deal didn't happen. I think I will have pull the pin and fabricate.
sicilian
Post by sicilian on Aug 22, 2013 16:22:58 GMT -8
The easiest and fastest way to remove the hinge pin is to chuck it in to a cordless drill. Spin it while removing or installing it and it is a breeze.
Post by mobiltec on Sept 15, 2013 10:12:36 GMT -8
The easiest and fastest way to remove the hinge pin is to chuck it in to a cordless drill. Spin it while removing or installing it and it is a breeze. Oh what a great idea. Here is a guy who parts out vintage trailers in the Mojave Desert in So Cal and he ships now. I bet he has a complete hinge set up for you. Chris 760 330 3402 Location: El Mirage 92301(just east of Lake LA.)
