Post by wisconsinjoe on Oct 30, 2014 21:18:50 GMT -8
Our original, almost new condition Dometic refrigerator (gas only) in our 1963 Friendship Vacationaire worked perfectly until our last trip when the flame suddenly refused to stay lit. Where to start looking for source of problem?
Post by vikx on Oct 30, 2014 22:19:38 GMT -8
Thermocouple. It's the copper probe close to the flame...
Also, the burner area may be full of debris; try cleaning with a vacuum or air blow. While you're at it, clean the "chimney". Often full of rust.
Post by wisconsinjoe on Oct 31, 2014 5:54:31 GMT -8
A buddy also said thermocouple. Not sure what you mean by chimney. I just have a louvered vent. Think I'd have to remove fridge to replace thermocouple?
Post by Ten on Oct 31, 2014 12:54:17 GMT -8
Not the photo I was looking for...this is the rear of the Astral that was in my Airflyte. You will likely have no choice but to remove the fridge from the camper to work on it, there just is not enough room to access the burner and the thermocouple from the interior of the cabinet. The thermocouple is a copper probe that inserts directly into the flame of the burner, on one end. It should be screwed into place. The other end should be mounted in the valve itself. The thermocouple tells the valve that there is heat, meaning a flame is present, so keep feeding the propane. If the flame goes out the thermocouple will cool and close the valve, stopping the propane from going to the burner and leaking into the cabin. The chimney, referred above, is simply the tube that reaches up through the compartment above the burner. It is usually a small diameter and has a baffle in it. It can become plugged easily with insects and their nests. It is not difficult to clean it out either, a little compressed air is plenty. Be sure to check the surface of the burner itself after the chimney gets blown out that no 'chunkies" plug the burner holes. It will not be directly connected to the outdoors, the ambient air flow simply directs to the outside through the louvered vent.
Post by wisconsinjoe on Nov 1, 2014 6:21:32 GMT -8
Thanks. Any tips on removing the fridge to work on it? How will I disconnect the gas line?
Post by wisconsinjoe on May 19, 2015 4:10:59 GMT -8
Ten and Vikx, thanks for the help. I did try to access the fridge by removing the outside vent, but could not get to the area I wanted. Then I discovered the original manual in the camper, which had a trouble shooting section that described my problem. I simply had to bend a flat piece of metal closer to the flame. I presume this is what you all called the thermocouple, but the manual refers to a "klaxon valve." I was able to reach it from the front bottom access panel. All is well now in the Vacationaire.
Post by Ten on May 19, 2015 5:26:34 GMT -8
Glad to here it's up and running again..and a simple fix. They can be a pain to pull out, and much easier when it is not necessary!
