queenofdarts
1962 Metzendorf 15
Post by queenofdarts on Aug 25, 2014 5:54:28 GMT -8
Hi all
I bought a jack caster to help me make small parking adjustments in the driveway. It is meant to be removable and has a sort of pin to keep it on. My tongue jack post (?) has no holes though to run it through. Do I try to drill holes? Or am I barking up the wrong tree and should send it back to Amazon?
Sandee
Post by bigbill on Aug 25, 2014 6:01:21 GMT -8
Assuming it has a sleeve that slides over the jack post it doesn't need a pin to hold it on while parked. Some people weld/bolt a stub to the trailer tongue to pin it to when not in use and some trailers that have a swivel jack pin it to the jack because it comes up out of the way when towing. The reason for storing on tongue is if it is muddy/dirty you don't have to put it in the trailer, but it is open to theft that way.
queenofdarts
1962 Metzendorf 15
Post by queenofdarts on Aug 25, 2014 6:51:25 GMT -8
Thanks BigBill! You have been amazingly helpful! It it supposed to just slide over. I'll give it a go and find something to store it in for when we're camping. It'll probably be dirty - at least if we're doing it right.
Post by Ten on Aug 25, 2014 14:54:05 GMT -8
Think something easy for storing it in...something like a tote bag or a reusable shopping bag is plenty, just to keep the "dirty" from getting all over...throw it under the bench or in a closet and you're set.
