suzy
1960 Shasta Compact
Post by suzy on Jul 27, 2014 11:37:28 GMT -8
Hello. Does anyone have a manual for a Holiday stove? I am trying to use it for the first time and am not sure how to light it. I assume I just turn on the burner and put a match to it, correct? Also, does the same go for the oven? I saw another string that mentioned a valve under the stove top but mine doesn't have a valve and the knobs are just on / off. This is for a 1960 Compact if that makes any difference. Thanks!
Post by SusieQ on Jul 27, 2014 12:34:57 GMT -8
I have the same one, no valves and On/Off on the knobs. We just lit the burners with a match and did the same with the oven. Be sure you open the door before you turn your oven on . I do suggest you test your lines first to make sure you don't have a leak.
suzy
1960 Shasta Compact
Post by suzy on Jul 27, 2014 13:00:15 GMT -8
Thanks for the confirmation SusieQ. I'll give it a try!
